C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E-force timing issues - Drag strip data
Old Dec 28, 2012 | 08:51 AM
  #61
Unreal's Avatar
Unreal
So whats the plan? Wait for edelbrock to send you something or just fix it yourself?
Old Dec 28, 2012 | 12:19 PM
  #62
Red Sleeper's Avatar
Red Sleeper
Not waiting on Edelbrock. Fixing it myself. Should be an easy fix. I'll fix the main timing table then data log it. I'll then set up a histogram for the timing table. Also, look for other probems. I'll probably have it fixed by the end of the day if the weather holds.
Old Dec 28, 2012 | 01:11 PM
  #63
Unreal's Avatar
Unreal
Do you know what the timing map should look like from Edelbrock? I'm sure you can find a maggie timing map which should get you close. If you can't I can send you the factory maggie map as a starting point.
Old Dec 28, 2012 | 02:42 PM
  #64
Red Sleeper
Thank you for the offer but I don't think I will need it.
It is fixed and drives great now.
What I did was copy the low octane map over to the high octane map. I drove it and all the problems just went away.
I did notice a couple of Knock retards in first gear. I'm not sure if it is a problem since the back end was loose. Pulling from about 4000 rpm no KR what so ever. I suspect I can get more aggressive on the timing there. Knock decay is way too long. I'll have to fix that.
For the most part the timing is very stable but something pulled timing a couple of times that wasn't KR related. Since I had the traction control off I'm not sure what it was. Maybe burst knock???
I know I'm on the correct path to optimizing performance and in a few days and after a trip or two to the track she be close to perfect.
NOW, I want to know what the hell happened! How could a faulty timing map end up in my PCM? Was it a defective SCT hand held programmer, or was it a corrupt update that I was required to download from Edelbrock's site, or was it a disgruntled employee. I actually uploaded the SCT tune twice just to make sure it wasn't a faulty download.
I think it would be wise for me to contact Edelbrock and let them know what happened so they can do a little house keeping.
Also, I would like to say, what a pleasure HP Tuner is to use. I am completely pleased with it. It took me about two weeks studying the demo and other things to get proficient with it.
Old Dec 28, 2012 | 03:22 PM
  #65
Drewstein's Avatar
Drewstein
That's the problem with canned tunes and why nobody should trust or use them. Just think, it could have cost you a motor if it went the other direction.
It's the equivalent of ordering that sandwich with no onions and getting onions on the first bite. Except these onions could cause some damage.
Old Dec 28, 2012 | 04:19 PM
  #66
Red Sleeper
By golly I have to agree with you. The proof is in the pudding!
Old Dec 28, 2012 | 04:44 PM
  #67
J Christensen's Avatar
J Christensen
Do you have complete control and tuning over the ECU/PCM, and can you also put in a new PCM and change it's VIN to your cars vin?
Old Dec 28, 2012 | 06:18 PM
  #68
45ACPDoubleTap's Avatar
45ACPDoubleTap
Had your car been previously tuned by someone?
Old Dec 28, 2012 | 08:01 PM
  #69
Red Sleeper
I read something about that but don't know all the particulars. I think it is in the Q/A section of HP Tuners. It will probably do it but you might have to use or buy more credits.
Old Dec 28, 2012 | 08:04 PM
  #70
Red Sleeper
No, it was bone stock. I have even compared the original stock tune with a stock tune on the HP repository.
Old Dec 28, 2012 | 08:47 PM
  #71
Red Sleeper
I just found another problem with the canned tune. The Power Enrichment EQ vs RPM table is the same as the stock tune. Calculates out at ~12.7:1. That probably explains a few knock retards in WOT. I'm going to fatten it up to ~11.0:1 and see what happens.
The transmission tune seems to be good. They actually did a good job on it.
Old Dec 29, 2012 | 09:26 PM
  #72
nullpointer's Avatar
nullpointer
How much timing are you running in the wide open section of your spark table after copying over the low octane table?
Old Dec 29, 2012 | 10:14 PM
  #73
Red Sleeper
Best way is to show you. I think this is conservative. Also keep in mind this run was with the stock PE table. So it went lean and there was a few degrees of timing pulled from knock. When the weather clears I will be able to correct the PE problem.
This might be better to show WOT timing.
Old Dec 29, 2012 | 10:41 PM
  #74
nullpointer
I agree, conserative on the timing side @ wot. Are you going to check the VE / MAF tables? (need a wideband for that) At this point I personally wouldn't trust any of the tables supplied by EB.
Old Dec 29, 2012 | 11:07 PM
  #75
Red Sleeper
I believe the VE/MAF is correct. It matches closely another older copy of the tune that was sent to me.
At least I have a starting point.
Old Dec 30, 2012 | 10:39 AM
  #76
nullpointer
If you notice that the AFR that you have in the PE table isn't what your wideband is reading then you need to work on the MAF table. I hope it's all set and that you only need to play with timing and PE.
Old Dec 30, 2012 | 10:41 AM
  #77
Unreal's Avatar
Unreal
It is very possible they just hacked up the Maf/VE table to get richer and didn't touch the PE. I wouldn't mess with fueling too much until you can get a wideband and see what is going on. I would bump that timing up too. 7-8 is too low. Get it up to at least 10-11.
To E-force timing issues - Drag strip data
Old Dec 30, 2012 | 10:43 AM
  #78
nullpointer
ugh that's horrible if they did that
I'm a tad late to this party and assumed he had a wideband.
Old Dec 30, 2012 | 11:43 AM
  #79
Red Sleeper
I really can't tell much about the MAF sensor as they used a different one from stock but it matches pretty well with the old copy of the base e-force canned tune I have. Also that tune has a much richer PE table which I copied.
What I'm going to do is faten it enough quinch the knocks if I can then bump timing until they come back or until I can run about 10* advance then start leaning it out.
Already it's far stronger than it was. I'll be tuning today and let everybody know how it turns out.
Old Dec 30, 2012 | 11:54 AM
  #80
Red Sleeper
It's horrible alright.
Late to the party?... Better late than never!
No wide band - but this old timer has been around the block a few times. I won't do anything too stupid I promice you. In the past we had to tune without wide bands. They had them but over the top expensive. We always got the job done.
My goal today is get as much timing as possible with no KR.
