C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
A bully
Old Jan 20, 2013 | 10:11 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Default A bully
Time to take the Z to the next step. I have been running the Texas Mile over the past several years. Fastest speed has been 197.6 mph. Looking to get over 200 mph. I registered for the Spring Texas Mile, So after that I started pulling the LS7 out of the Z. I will take some pictures along the way to show the progress.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Engine is removed and will be reinstalling the new ERL sleeved 427 over next weekend. YSI will a little juice should get me into the 200 mph range. It has been a long journey over the last couple of years collecting parts for this build. I am usually busy working on other people's cars, So now it is time for my build. I will try and update the progress over the next couple of weeks.
Old Jan 20, 2013 | 10:48 PM
Unreal's Avatar
Unreal
What pulley sizes are you running on the Ysi? Looks like a great setup.
Old Jan 20, 2013 | 11:01 PM
LeftLane Z06's Avatar
LeftLane Z06
what kinda under tail is that?
Old Jan 20, 2013 | 11:35 PM
Detoxx03's Avatar
Detoxx03
Man that thing is beautiful.
Old Jan 20, 2013 | 11:58 PM
C6z06man's Avatar
C6z06man
Man I love that!!
Old Jan 21, 2013 | 01:55 AM
winters97gt's Avatar
winters97gt
Badass, Arnold.
That car should rip with the YSI on dope. I'll be out there to see you run. Are you tuning the car, or is Corey at Henderson or Pat G?
Old Jan 21, 2013 | 04:36 AM
walhan_qtr's Avatar
walhan_qtr
good luck. very nice looking car!
Old Jan 21, 2013 | 08:07 AM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
2.85 pulley, overdrive balancer
Breathless Performance diffuser, 4 tip
Mark, Not sure on tunning yet, Corey has tunned very well for me in the past, So I will give him first shot. It is going to be a hand full at the Mile.
Old Jan 21, 2013 | 08:37 AM
winters97gt
Nice. Are you running an 8 rib with a direct drive? 2.85 will most likely slip without one. I've got one not being used if you don't.
Eitherway, 200mph should be in the bag off the spray. Wouldn't be surprised to see 210 on it!
Old Jan 21, 2013 | 09:02 AM
Unreal's Avatar
Unreal
Winter, the pictures show a DD direct drive and 8 rib so I'll answer that for him and say yes.
I don't see 6 bolt heads. What head setup/gaskets/studs are you running? Aren't you worried about head gaskets?
I'm running a 2.85"/7.25" but need to swap to the 8.0" when I stop being lazy. Can't decide to do it before or after I move to Texas.
Old Jan 21, 2013 | 10:21 AM
Silver Bullet C6's Avatar
Silver Bullet C6
St. Jude Donor '10-'11-'12
Looks very nice...can you share the approximate cam specs? I have a similar set up, but with no nitrous.
Old Jan 21, 2013 | 10:25 AM
frc's Avatar
frc
Very cool!
Old Jan 21, 2013 | 12:07 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Nice tag!
Old Jan 21, 2013 | 06:11 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Good luck with whoever you choose to tune it.
Old Jan 21, 2013 | 10:53 PM
playtoy's Avatar
playtoy
If the car is set up right he shouldn't need them. I'm running a F2 on pump gas with a 4 bolt block. A good set of heads and a good tuner and there shouldn't be a problem.
Old Jan 21, 2013 | 10:55 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
I am a little worried about the head gaskets. I was not planning on running the YSI when I ordered the engine.
As for camshaft specs, Check with Lethal Performance or JM as it is one of there camshafts. They are on top of things at this hp level.
Old Jan 22, 2013 | 06:08 PM
Jaycajun's Avatar
Jaycajun
I sure would like to come over to your house and check it out since I live 5 minutes from you!
To A bully
Old Jan 22, 2013 | 06:13 PM
BADZ's Avatar
BADZ
It looks nice bro, always nice to have another YSI brotha!!!!!
You should see easy over 200 mph without the gas!!!
Old Jan 22, 2013 | 09:02 PM
AKS Racing's Avatar
AKS Racing
Arnold - Looks very nice!
Wish I could attend the mile event, but need to continue to keep things under wraps, for now. I know you have been waiting to drop the engine in the Z for a long time. I'm certain it will come out very nice.
Old Jan 22, 2013 | 09:50 PM
winters97gt
2.85+spray! Wow! My car was making like 800rwhp with that pulley around 5200rpm before it threw the belt each time, on a 402 with that blower. I'm guessing 210mph dependent upon DA and wind.
