C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
A bully
Old Jan 22, 2013 | 09:50 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Looking forward to seeing you hitting the 200 mph mark with your new setup and about time you went blowin
Old Jan 23, 2013 | 11:48 PM
57trimMKIII's Avatar
57trimMKIII
2nd Gear
Looking good Uncle Arnold! See you at TX2K13
Old Jan 23, 2013 | 11:53 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Nice! Loving my ERL superdeck 6. You will too! Good luck and be safe!
Old Jan 25, 2013 | 10:24 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Update A! You have it in the car yet lol
Old Jan 26, 2013 | 09:51 AM
Slo-Poc's Avatar
Slo-Poc
So sick I love this build! can't wait to see who makes it to tx2k13 this year. Last year I had heard a bunch of upper hp vettes were going to be there but on really saw that c5z.
Old Jan 26, 2013 | 08:01 PM
ajrothm's Avatar
ajrothm
Awesome build! Gorgeous car as well...
Old Jan 26, 2013 | 09:19 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
I installed the engine today. No time to work on it during the week. Ran into some issues with the aftermarket scattershield. I had already modified it for the headers and trans cooler lines. I also had to modify the slave cylinder lines, Just did not make them big enough before I stabbed the the engine. Had to back out some and regrind a little larger. Hope to get the intake, cooling system and intercooler in tomorrow. Should be able to fire up late in the day. Then time for all the extras, Meth, aux fuel pump and Pfadt sway bars. Still need to order larger injectors, Looking at the Bosch 1200 from Arun. Will do the break in miles with the current injectors. Hope to get on the dyno in the next couple of weeks. I will post some more pictures tomorrow evening.
Old Feb 5, 2013 | 11:11 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Update! Put down the bud light!
Old Feb 5, 2013 | 11:14 PM
rattt g's Avatar
rattt g
where is the fogger
Old Feb 6, 2013 | 09:36 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Been out of town the last couple of days, Did not get much done over the weekend. Radiator and intercooler mounting figured out and clearance for all the lines and fans. Hopefully this weekend will be more productive.
The fogger will be installed right before the throttle body. Looking at an aftermarket intake now to change the look a little and add some more hp.
Old Feb 10, 2013 | 09:02 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
I got the Z running this weekend. Runs a little rich due to the camshaft change, Need to get a quick tune and then some break in miles. Still need to build the fuel system and change injectors/intake assy. Need to add meth and install gauges. Changed the trans fluid with Royal Purple, Hopefully it will shift like butter.
Old Feb 10, 2013 | 10:01 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Great you are up and running wish I was out there for the initial firing
Old Feb 10, 2013 | 10:03 PM
  #33
winters97gt's Avatar
winters97gt
Are you on the factory Tr6060? I know mine wasn't a fan if 800-850rwhp 5th gear pulls, and I know you've gone in to 5th a ton of times at the mile.
Old Feb 10, 2013 | 10:19 PM
  #34
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Factory trans with no upgrades. Talked to a local performance trans builder and he recommended no upgrades on the 6060. The gear setup in perfect for a 215 mph run. It will be in 5th for the last 1/2 mile.
Old Feb 10, 2013 | 10:25 PM
  #35
winters97gt
Yeah, I noticed you shift to 5th in a video I saw of you before the 1/2 mark at Goliad, I believe. We kind of calculated that on a 26.5 inch tire, 215 was what base gearing is good for depending on RPM's. Our cars will do 172 @ 6800rpm in 4th, but on 17's with tire inflation. R6's probably don't inflate much, though. You might set the fastest street driven vette record!
Old Feb 11, 2013 | 10:36 AM
  #36
harleyreb1's Avatar
harleyreb1
Best of luck to ya!! I'll be there in March watching, plan on bringing car in October and going for the 190 club!
Old Mar 3, 2013 | 11:14 PM
  #37
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Latest update on the progress. I have been driving for the last week. I put about 400 miles on it. Still not dyno tuned, Will have to wait until the fuel system is built. Raised the washer tank to install the meth kit. Had to add some roller to the radiator support due to my steep driveway. Not real happy with how low the header hang. The engine and blower sound really good, If you like it loud. Here are some pictures of the progress.
[IMG]
To A bully
Old Mar 3, 2013 | 11:51 PM
  #38
winters97gt
Looks fantastic! I've got a C6 plate you can have for the juice if you want it instead of the fogger.
That IAT looks real close to one of the meth Nozzles. Are you getting good logs?
Old Mar 4, 2013 | 09:44 AM
  #39
ajrothm's Avatar
ajrothm
Beautiful!! Nice work!
Keep us posted on it numbers/speed...
Old Mar 4, 2013 | 10:11 AM
  #40
breecher_7's Avatar
breecher_7
Even with a DD I would expect belt slip with that 2.85" pulley on a 8 Rib. 10 ribs even start slipping pretty bad once you get that small. You may as well go for a 2.70" though since you are down there..
