flip drive kits
It needs to be a smaller pulley, You would need the a/c mounting bracket and idler from a C5. It should work fine. You would have to have a longer 4 rib belt. Might be able to get the same result by just reclocking the tensioner on the a/c drive and then adding a longer belt.
It should fit fine. I would look at reclocking the factory tensioner. It looks like there is plenty of room and would give more belt wrap than adding the C5 bracket.
