C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Edelbrock E-Force DIY Install
Old Dec 21, 2013 | 12:54 PM
  #61
Red Sleeper's Avatar
Red Sleeper
Originally Posted by realcanuk
That sucks. Agree more details would be nice. Maybe a tune issue with the added boost and new injectors ?
Do you know of anybody else on the forum that has blown up their E-Force?
Old Dec 21, 2013 | 01:09 PM
  #62
1BADLS's Avatar
1BADLS
My car was an A6. I believe the shift points were set to shift at 6400rpm. The motor blew on my 5th pass as I crossed the 1/4 mile finish line.
I have already sold the car and purchased this 2010 Grand Sport.
Old Dec 21, 2013 | 01:54 PM
  #63
Red Sleeper
Wow, you must have sold it to the rollback owner. Good looking Grand Sport.
I have been shifting slightly above 6400 rpm. I believe I'll pull that back a little. Maybe to 3500 rpm (kidding).
Old Dec 21, 2013 | 03:31 PM
  #64
da_vato's Avatar
da_vato
@BlownLS3, was it the crank or a rod that gave out? I ask because the dry sump LS3's are supposed to have a stronger crank from what I understand.
I think I read somewhere that you were producing 11 PSI is that right?
Old Dec 21, 2013 | 04:49 PM
  #65
1BADLS's Avatar
1BADLS
Originally Posted by da_vato
@BlownLS3, was it the crank or a rod that gave out? I ask because the dry sump LS3's are supposed to have a stronger crank from what I understand. I think I read somewhere that you were producing 11 PSI is that right?
It was a connecting rod, not the crank. The rod broke in the #1 cylinder just below the piston. It had a clean break when it was removed. I believe it was pushing 11psi based on the last dyno tune. My LS3 was a wet sump car.
Old Dec 21, 2013 | 05:41 PM
  #66
arp35's Avatar
arp35
Great looking GS. What damage was done to the EForce? Also, just curious, but what kind of money do you get for a C6 minus an engine?
Old Dec 22, 2013 | 08:56 AM
  #67
1BADLS's Avatar
1BADLS
I basically got $18,000 for my C6 Coupe. I have been back several times to see how the repair is coming. They put it back to stock. So far, they must have at least 40 hours into the repair.
