C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost controller for centri
Old Dec 11, 2013 | 09:49 PM
LethalTT's Avatar
LethalTT
Default Boost controller for centri
Would this setup work? Riding on Nitto invo 345 with 1000hp is no fun.
https://www.easyperformance.com/prod...t%20Controller
Old Dec 12, 2013 | 11:49 AM
LethalTT's Avatar
LethalTT
Well I called them and it only works for corvettes with a roots style blower. They are working on a system that will redirect power for a Centri but it could be awhile. Well life still sucks for us Centri guys that don't have drag setups for the street.
Old Dec 13, 2013 | 12:22 AM
jon6.0's Avatar
jon6.0
Contact Dallas Performance. They have a setup for centri's.
Old Dec 13, 2013 | 01:00 AM
LethalTT's Avatar
LethalTT
I did contact them and they pm'ed me saying they don't have anything.
Old Dec 13, 2013 | 01:04 AM
jon6.0's Avatar
jon6.0
I was thinking of their boost by gear setup for centri's. http://forums.corvetteforum.com/c6-f...other-one.html
Old Dec 13, 2013 | 01:06 AM
jon6.0's Avatar
jon6.0
There is no reason a good shop couldn't put a wastegate on your inlet piping to bleed off pressure. Then it's just a matter of choosing your preferred boost controller and programming it. Or just using a simple dual stage solenoid activated boost controller like a Turbosmart. Have low boost for daily and then a kill setting for Mexico.
Old Dec 13, 2013 | 10:39 AM
Unreal's Avatar
Unreal
Its more complicated than that.
Old Dec 13, 2013 | 11:14 AM
jon6.0's Avatar
jon6.0
The easiest solution is just don't mash the pedal all the way if the tires won't hold.
Old Dec 13, 2013 | 12:15 PM
lt1z's Avatar
lt1z
Old Dec 13, 2013 | 03:15 PM
NSANEC6's Avatar
NSANEC6
Old Dec 13, 2013 | 03:57 PM
Unreal's Avatar
Unreal
From my research you just don't bolt on a gate and controller and go. Sizing the gate and spring is some trial/error. I've seen boost curves look like a sine wave generator with it bouncing up and down. It can be done, but there is more to it than just put on a gate and go.
Another thing I've seen is spring a BOV to open at a certain PSI without pressure to the top with a solenoid, then when the solenoid opens it pressurizes the top and acts just like a BOV.
To Boost controller for centri
