C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Nitrous help
Old Apr 25, 2014 | 08:04 PM
Dallas 123's Avatar
Dallas 123
Default Nitrous help
Has anybody done nitrous set up in Dallas/Fortworth area, TX that would recommend a performance shop that they have experience with, and how much nitrous they're running for how long and what setup on the motor (zo6). Please reply. Thank you
Old Apr 26, 2014 | 11:08 AM
lane_change's Avatar
lane_change
Get a hold of Carlos from Vette-Air or Quality Motorsports.
Old Apr 26, 2014 | 01:17 PM
corvette8189's Avatar
corvette8189
100-150 plate or nozzle kit
Good gas and tune will last forever
You can install yourself not to hard, if interested I can get you a NX kit
Old Apr 26, 2014 | 01:29 PM
ProEFI's Avatar
ProEFI
Supremacy 1 car at a time
I didn't let anyone install my nitrous kit find your self a time and do it at home it's easy and lovely to work with.
Old Apr 26, 2014 | 06:37 PM
Dallas 123's Avatar
Dallas 123
Thank you for your reply. I don't know how to tune it and worried that I can make a mess.
Old Apr 26, 2014 | 06:38 PM
Dallas 123's Avatar
Dallas 123
How much nitrous are you running and what set up in what car.
Thx
Old Apr 26, 2014 | 07:03 PM
ProEFI's Avatar
ProEFI
Thx
05C6 - HARRIS speedworks 92mm EFI wet nitrous plate system (125hp shot)
02 Camaro - HARRIS speedworks wet nitrous fogger system (200hp shot)
06 C6Z - HARRIS speedworks wet nitrous fogger system (200hp + 200hp shot)
I'll recommend to you the MicroEDGE nitrous controller from HSW!
the MicroEdge is a technology leader in the nitrous industry. But those aren’t even all of the features that are included! The MicroEdge was also designed to work on any rpm signal, from individual coils/coil on plug to crank position sensors. RPM signal can also be obtained by using the fuel injector or tach output signal.
Old Apr 26, 2014 | 07:54 PM
corvette8189
Install it then have it tuned. If the car is stock I would have no problem using a 100 shot on the stock tune
Old Apr 26, 2014 | 10:22 PM
dennis50nj's Avatar
dennis50nj
Harris speed works has been out of business for years
Old Apr 28, 2014 | 10:06 AM
dekan513's Avatar
dekan513
i have a harris speed workds kit. i run a lnc2000 to pull timing and a nos launcher controller. ran my ls3 camaro on a 150 for a long time. running a 100 hit on my ls3 vette now on stock tune. just check your plugs and run a colder plug for the hit .
Old Apr 29, 2014 | 12:10 PM
EX1's Avatar
EX1
I run a 125 shot on my h/c/i/e LS7. Been spraying for a couple of years now. Currently on a 125 dry shot. Numbers are in my sig. Just be sure you have a solid tune and run good fuel. Those are the two key things here.
Old Apr 29, 2014 | 06:34 PM
andyyi's Avatar
andyyi
Cruising
dallas performance is great too
Old Apr 29, 2014 | 06:55 PM
ProEFI's Avatar
ProEFI
yeah, but you'll find someone wanna sell his kit for sure such as the post that following you.
To Nitrous help
