C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
DashLogic Discount
Old Jun 16, 2014 | 12:40 PM
BAMAGOLFER's Avatar
BAMAGOLFER
St. Jude Donor '06-'10-'11
Unreal thanks for the help.
But I didn't see anything listed for MAP-BARO on the basic list. Is this something that's in the advanced section?
And what are PID's?
Pardon my ignorance, just trying to learn all this stuff and why do I need to monitor it.
Kelly
Old Jun 16, 2014 | 12:51 PM
NJGS11SC's Avatar
NJGS11SC
I believe it is "Calculated Boost" on the list or something similar to that.
And what are PID's?
Kelly
Old Jun 16, 2014 | 01:17 PM
BAMAGOLFER's Avatar
BAMAGOLFER
I didn't see anything that referred to or mentioned Boost on the list.
Old Jun 16, 2014 | 01:53 PM
PalmerPerformance's Avatar
0PalmerPerformance
Former Vendor
It is PID 30001, it is now a default PID on the default layout on version 1.17 and on.
Old Jun 16, 2014 | 02:31 PM
Streetk14's Avatar
Streetk14
A couple things.....
1) I've mentioned this a bunch of times in other threads, but you NEED to replace your MAP sensor to read boost above around 3 psi. The stock LS3 and LS7 MAP sensors only read to 120 kpa.
2) I made a "calculation PID" for my boost reading. When I get home I can post the formula you need to enter.
Old Jun 16, 2014 | 02:51 PM
NJGS11SC's Avatar
NJGS11SC
Thanks....
Do you still need to change the sensor with your calculation pid?
Old Jun 16, 2014 | 03:18 PM
Streetk14's Avatar
Streetk14
Originally Posted by NJGS11SC
Thanks....
Yes, the stock ls3 map sensor simply cannot read more than 120 kpa (3 or so psi). Buy a ZR1 map sensor, change the calibration data in your tune, and you'll be good to go.
I think the confusion is that the Palmer guys have posted a few times mentioning that boost can be read off the stock sensor. If you have a LS9 or LSA car, this is true. It's also partially true for the LS3 -- it'll read boost, but not much.
Old Jun 16, 2014 | 03:28 PM
Unreal's Avatar
Unreal
Yes, it only reads what the sensor puts out. If you don't want to change the values in the ECU just wire in any 2/3 bar map, run a vacuum hose to it and the output to the analog in.
Old Jun 16, 2014 | 05:38 PM
NJGS11SC's Avatar
NJGS11SC
I confirmed with the ECS guys that I do have the ZR1 map sensor installed.
Will the calculation you mentioned previously now true up my readings or do I need to do something custom for my car?
Old Jun 16, 2014 | 11:45 PM
Streetk14's Avatar
Streetk14
Assuming they changed the calibration values in your tune, then you should be good.
I'm out again on my phone, but I'll get that formula for you. Mine originally didn't read right either, but I probably wasn't using the correct PID. A calculation PID that shows vacuum and boost is the way to go.
Old Jun 17, 2014 | 10:26 AM
BAMAGOLFER's Avatar
BAMAGOLFER
I found that PID(30001) and did get it working. It shows vacuum & boost.
When I drove to work today I got into it and it showed 5lbs of boost. I think it was only 5 due to the pulley I have on the SC.
Have emailed Hennessey and will find out if they did put in a ZR-1 MAP.
Kelly
Old Jun 17, 2014 | 01:19 PM
0PalmerPerformance
Former Vendor
Yes it is our fault, we assumed that people were not running around with MAP sensors that were pegged out. We thought that all SC kits would include a provision for that.
Old Jun 17, 2014 | 09:47 PM
  #33
Streetk14's Avatar
Streetk14
Unfortunately, no. I don't think ANY of the supercharger or FI kits include a new MAP sensor as standard. Although the ZR1 sensor is only $40 or so, I think it all comes down to trying to be as competitive on pricing as possible.
You can "tune around" the stock MAP sensor as many do, but I wouldn't call it the right way to do things. Even when tuning a MAF car, it's nice for the PCM to have accurate MAP data so the injector flow rates at correct under all driving conditions.
Originally Posted by vette217
does this do the rev match and gear indicator on a c6? Thanks
Could you elaborate on this some more?
Old Jun 17, 2014 | 11:19 PM
  #34
Unreal's Avatar
Unreal
I believe the PD kits come with maps. Eforce, Maggie, etc.
Old Jun 18, 2014 | 09:24 AM
  #35
old motorhead's Avatar
old motorhead
The Magnuson Heartbeat doesn't.
Old Jun 18, 2014 | 10:03 AM
  #36
Streetk14's Avatar
Streetk14
I think it's only the E-Force that does, since they change to that T-MAP sensor. Magnuson has always had you swap over your original sensor during install. I don't think Whipple supplies a new one either.
Old Jun 18, 2014 | 06:53 PM
  #37
v8rx7com's Avatar
v8rx7com
We have dropped all DashLogic prices to introductory pricing ($249.95)!! Don't miss out on the deal!
Your website shows it for $299.95 for the C6 Corvette .... but $249.95 for all other applications?
To DashLogic Discount
Old Jun 18, 2014 | 08:38 PM
  #38
needcheese's Avatar
needcheese
I concur with this statement. I was about to get one tell I saw the price difference. Please, let us know.
Thanks,
Old Jun 19, 2014 | 09:46 PM
  #39
0PalmerPerformance
Former Vendor
We took a huge hit to the stock on hand. We have a shipment showing up any day now, until then, I don't dare leave the price where it was until I can be sure I can fill all the orders.
Old Jun 19, 2014 | 11:27 PM
  #40
ATLS2's Avatar
ATLS2
Got mine today! Thanks
