best supercharger for c6 base
I had a tuner add a Magnuson "heartbeat" PD unit. It is new technology, and deals with the "heat soak" problem others have mentioned. You can watch the Magnuson Youtube to learn more. Also, there is a Youtube of Lingenfelter (I think) with a motor on a test stand and a Magnuson Heartbeat making 900+ Flywheel HP.
Stock LS3, upgraded with Magnuson Heartbeat, Trickflow heads, custom blower cam, and Billy Boat long tube headers. 600 RWHP at 5# boost on premium pump gas. Great as a daily driver. Everything fits under the stock hood, saving a ton of parts and paint $. Only the fantastic loping idle gives it away (oh yeah, and the smoking tires too).
Also, there is nothing "new" about that technology regardless of whatever propaganda you have read (and lingenfelter is real good for marketing propaganda), nothing they have changed from the original TVS 2300 makes the IAT's any lower, just the oposite actually. The actual original TVS 2300 head unit that magnuson offers will outperform the "heartbeat" because it isnt chopped down to fit under a stock hood. Taking the length out of the intake runners and making the package more compact makes the IAT's less manageable.
I'm still working on the power end of things. The Heartbeat is somewhat limited in that the smallest blower pulley available is a 3.2". Being a front drive, there's no overdriven rear pulley option. That should be enough for about 700 at the wheels once I get things sorted out. I've had belt slip issues that were "diagnosed" as just about everything but plain old belt slip.
You could be more wrong, but you'd have to try hard. The Heartbeat is head and shoulders better than a jackshaft Maggie in the IAT department. I've owned both in different LS3 powered Vettes. At cruise, the IAT's are very similar. 10 to 15 degrees over ambient. Under boost, the Heartbeat goes up only about 20 degrees and recovers as soon as you lift your foot. The older Maggie goes up almost twice that much and doesn't recover near as quick. The heat exchanger is an upgrade vs the older Maggie. The intercoolers are also a step in the right direction.
3.2" pulley on a YSI would make over 800whp with ease (and cooler intake temps!)... Just sayin....
I must admit though... The current TVS 2300 and Heartbeat units are light years ahead of what was available when these screw blowers put a bad taste in my mouth. Still though, they run to hot for my liking and they just dont make enough power in my opinion. I will never disagree that they are fun to drive because they are. But shredding the tires at 2000rpm gets old pretty quick.
There you go... Chasing power with a heat pump again...
Oh....and huge power available on the low end NEVER gets old. You don't have to destroy the tires to feel it
Would the recommended choice of a PD or a centri style blower change based on the cars transmission? Is one better for an auto equipped car vs a manual equipped car?
For a mild street app, p/d is your answer. More power than stock at any rpm above idle. Transmission choice matters little. Full boost is always available at just about any rpm you choose to use it.
You need to decide how much power you want and how you want said power delivered. If you know you'll eventually want 700+ rwhp, centri is your easiest way to get there. Not saying that a p/d won't get you there....just takes more $'s.
Former Vendor
the heart beat is a great blower and has a wicked seat of the pans feel. making the car very fun to drive. I can set you up with the heartbeat when you are ready
#33
I've driven (and rode shotgun) both a PD and a centri based LS3 stick shift.
It wasn't a fair comparison as the centri was in a heavier Camaro and it had a cam (650/650ish). The PD I drove was the E-Force (made 580rwhp/611rwtq).
Driving the car: It "feels" more powerful down low on the PD (helped it's a much lighter car I drove) and while it pulled hard at redline the Camaro with the centri pulled like a freaking monster up top. The whole car lifted up.
Passenger seat: both felt really strong but man oh man the centri ripped and was downright scary
Needless to say, I bought an ECS 1500 (centri) and it's getting installed in about two weeks. If I remember, I'll chime back in here.
#34
If you are in NY, I would take it to ECS in Cream Ridge, NJ. Install a blower and alky control system on my 2008 base about 2 years ago and I could not be happier. Great guys and great work.
#36
Cruising
I am interested in putting a supercharger into my base C6. I have a SLP CAI and Cora catback exhaust. Can anyone recommend the best supercharger for this car? Most hp gain and price. I read a lot about "ProCharger" and some guys are saying the Edelbrock retains its value but I do not know. Help is appreciated.
#37
Received 3,095 Likes
2021 C6 of the Year Finalist - Modified
For a daily driver that spends most of it's operating time at lower RPMs, I installed a PD supercharger just for the lightning fast throttle response and high torque at low RPM ... plays hell with the rear tires ! . .
Magnuson 'Heartbeat'
2011 GS with automatic transmission and a 2,800 stall converter ...
Attachment 48331544
Attachment 48331311
Attachment 48331544
Attachment 48331311
