C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Old Apr 2, 2015 | 09:21 PM
killakane1427's Avatar
killakane1427
Default 402
What rods and pistions did some of you use for your 402 builds with blower
Old Apr 2, 2015 | 09:55 PM
ajrothm's Avatar
ajrothm
I can tell you DON'T use a Compstar crank...
I think the best all around combo is a Dragonslayer crank, Ultra H Beam rods and Wiseco or Diamond pistons..
Old Apr 2, 2015 | 10:32 PM
killakane1427
What's wrong with callies compstars. And what about manley pistions
Old Apr 2, 2015 | 10:56 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Really depends on your power level. IMO you can cheap out on rods. They rarely fail. Put the money in the pistons as they are the most commonly failed part. Wiseco. And if you're staying under a grand you don't need a fancy crank either (again, IMO), but cheap ones flex under big power.
Old Apr 2, 2015 | 10:59 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I'm with ajrothm....
Used dragonslayer, Ultra Billet H beams, and Wiseco pistons.
Old Apr 2, 2015 | 11:04 PM
killakane1427
Iam go be like 850 or 900.
Old Apr 2, 2015 | 11:05 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
For that power, do it right the first time. It is cheaper in the long run.
Old Apr 2, 2015 | 11:08 PM
killakane1427
My builder is going with compstars and manley pistons..
ajrothm's Avatar
ajrothm
DEFINITELY don't use a Compstar at 900rwhp if its a blower car... TRUST ME..
Call Callies, talk to Justin Whitman or Brook Piper, they'll tell you the same thing.
I'd trust a stock crank over a Chinese Compstar at 900 rwhp. 900 rwhp with a blower will flex a Compstar.
I think the Compstar rods are ok for 900-1000 rwhp... Even Callies will tell you not to push them over 900 CRANK hp.
Old Apr 2, 2015 | 11:11 PM
ajrothm's Avatar
ajrothm
+10000
I'm going thru this right now myself. Spent $10k on a motor, used Compstar stuff, 8k miles later, rebuilding the motor again because the Compstar crank flexed and took out #4 main.. $7k to rebuild/upgrade to Dragonslayer crank/Ultra H Beams.
Spend more upfront and save you a ton down the road.
Old Apr 2, 2015 | 11:12 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
You need to make those decisions with your builder. When I built my 402 I was thinking about 700 rwhp max, and the builder was going to use a compstar crank and rods. After a little thought, reality set in and I realize I would want more power so I upgraded at that time. Sure enough, now at 1000 I doubt the compstars would have worked out.
I always prefer to over build a little, rather than under build.
Old Apr 2, 2015 | 11:13 PM
killakane1427
I will talk to my builder about that. I don't know. This is my first build like this but not his. I think 850 is the max it will make with the ecs 1500 kit so will the callies hold 850
Old Apr 2, 2015 | 11:15 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Originally Posted by ajrothm
+10000
Perfect example. The upgrade to dragonslayer, ultra billets, and heavy wall wrist pins was 1150.00 at the time of build. In hindsight........great value.
Old Apr 2, 2015 | 11:17 PM
ajrothm's Avatar
ajrothm
I was at 850 rwhp for 8k miles, 15 passes and quite a few highway hits... Lost oil pressure, yanked motor, #4 main bearing was smoked. That's where the crank flexes, right in the middle.
Penny up the extra $600-700 now for the dragonslayer, it will save you thousands down the road man....Just sayin...
Old Apr 2, 2015 | 11:27 PM
killakane1427
Ok cool. Dam i diff don't want that **** ****
Old Apr 2, 2015 | 11:38 PM
Detoxx03's Avatar
Detoxx03
Spend now and do it right. Don't skimp on important stuff like fuel systems and forged internals.
Old Apr 2, 2015 | 11:50 PM
killakane1427
So callies makes the dragon slayer or no
To 402
Old Apr 2, 2015 | 11:53 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Yes
Old Apr 3, 2015 | 12:03 AM
killakane1427
Ok iam going to ask which parts are going in 2morw
Old Apr 3, 2015 | 12:29 AM
killakane1427
Scat rod callies crank and manley piston is what i think he wants to go with. I will check thou
