What crank shaft sensor do I need to buy? I put wrong title can someone change it? I have a LQ9 based iron block 408 with 58X reluctor wheel. I keep getting a P0335 and P0336 code when it gets warmed up it is hard to start and runs rich. I have shield on starter to protect from up pipe off turbos. I assume I just unbolt it and put it in the way it comes out. Thanks.
Update: This noise has appeared after adding my exhaust. I have sealed everybody from the manifolds to turbos, to exhaust and I have no IDEA WHAT IT IS. I have good oil pressure and the noise starts around 2k-3k. When car gets hot It starts like this and spots a P0336 crank code.
Reason: Add video
