C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
nitrous
Old Jul 14, 2015 | 06:01 PM
killakane1427's Avatar
killakane1427
Default nitrous
adding my fuel system to my 402 built ls3 supercharged making 720hp right now. What kit should I go with if I add spray was thinking of only a 75 or 100 . motor is forged and have the other supporting mods. Thanks only go use it for half mile events and maybe some track days
Old Jul 14, 2015 | 06:17 PM
Nitrous Express & Snow Performance's Avatar
Supporting Vendor
I'd be happy to help you out with a kit.
Plate Kit
http://www.nitrousexpress.com/20934-...lb-bottle.html
Or you could run a proton kit
http://www.nitrousexpress.com/20420-...lb-bottle.html
Then the extras purge, heater, window switch, etc.
Let me know what all you want and ill be glad to get you a price as well as a forum discount.
Old Jul 18, 2015 | 10:29 AM
killakane1427
Plate Kit
My tuner said a plate kit might not work. Not sure why do looking for a 100 shot
Old Jul 18, 2015 | 03:31 PM
Supporting Vendor
Are you running a stock intake manifold?
A plate kit should work just fine.
Old Jul 20, 2015 | 12:20 PM
NitrousOutlet's Avatar
0NitrousOutlet
Former Vendor
Got any pictures of the set-up? I got a few ideas in my head but I want to see what you have first. Also what fuel are you running? And are you on the factory PCM or are you running an aftermarket set-up?
-Lance
Old Jul 20, 2015 | 12:40 PM
killakane1427
My tuner does a mix with the a and a kit with the ecs fuel system. Doing the fuel system with the spray
Old Jul 20, 2015 | 07:32 PM
Kadorja's Avatar
Kadorja
Plate may not fit with a centrifugal supercharger backet. Had that issue with my setup.
Old Jul 21, 2015 | 09:35 AM
Supporting Vendor
Then the best way to go is the nozzle setup. The proton kit I posted above will work great. PM me for a forum price.
Old Jul 21, 2015 | 10:11 AM
0NitrousOutlet
Former Vendor
What fuel system are you running, really need more information before people start throwing system at you. Are you running the factory PCM? And what fuel.
-Lance
Old Jul 21, 2015 | 01:12 PM
Supporting Vendor
We possibly have a plate they may work, we have a very thin 90mm plate or a single nozzle system, that will work with pump gas, race fuel, or e85.
In almost any case the single nozzle system will work, (stand alone EFI or factory, and almost any fuel combination, Forced induction or N/A, but those options would affect the jetting pattern).
We wouldn't just throw a system at you without getting all the specifics when we do the order, but at least you can get an idea of what your options would be.
Once we see pics we would know for sure if we could make the plate system work, then we can discuss the correct option for your application.
To nitrous
