C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
S/C Install complete!!
Old Aug 15, 2015 | 07:55 PM
Chokeu's Avatar
Chokeu
Default S/C Install complete!!
Supercharger is in! Now I have to wait until Monday to drop the car off to Granite State Tuning/Dyno for it's final tune. Has a startup tune on it now so I sit and wait.... Anyone guess what the final numbers will be?
2005 Convertible
Stock LS2
Stock 4L65-E
Kooks LT 1 7/8"
Kooks 3" X-Pipe (no cats)
160' Thermostat
CoW Booster Throttle Mod
Trick Flow Specialties HB
3.15 Gears
ECS Novi 1500
ECS Alky Control Meth Kit
Huge thank you to Malcolm @ Series Motorsport Hooksett, NH for the spotless install!!
Thanks to Matt @ Florida Speed & Power and also to Doug & Alex at ECS for all your help!!
Old Aug 15, 2015 | 07:58 PM
Chokeu's Avatar
Chokeu
Quick couple of questions......my tuner has VP M1 and M5 in stock, which one should I use?? Also, Doug at ECS said they normally remove the restrictor when Meth is installed so I took it out. Will this cause any issues?
Old Aug 15, 2015 | 08:10 PM
Kadorja's Avatar
Kadorja
M5 can make more power but my local place gets more M1 in stock so I use that instead. If there's plenty of M5 around you go with that.
Old Aug 15, 2015 | 08:18 PM
StingrayRebel's Avatar
StingrayRebel
I believe m5 has more additives and is not pure meth while m1 is almost 100% pure and doesn't have any addiditves... not sure what the addidives do but my guess would be to help with corrosion resistance since meth is so strong... most would probably use m1 and to be honest I don't think it really matters all that much since we use it as a secondary fuel and not a primary fuel... I just get generic meth from a local race shop, it has worked great and is less expensive (around $3 a gallon in my area)... some hobby stores may carry it too... the only issue taking the restrictor plate out will cause is more boost and more power
Old Aug 15, 2015 | 08:20 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
M5 has additives. Lubes, etc. for when using it as a primary fuel.
I'd use M1
Old Aug 15, 2015 | 08:25 PM
Chokeu's Avatar
Chokeu
Cool looks like it's gonna be M1. Any guess how much rwhp and tq?
Old Aug 15, 2015 | 08:35 PM
RicardoFors68's Avatar
RicardoFors68
Looks great, I'm patiently waiting for mine to arrive.....with the meth you should be at just over 600rwhp
Old Aug 15, 2015 | 08:42 PM
Arctic Vette's Avatar
Arctic Vette
My guess 630whp
Old Aug 15, 2015 | 08:45 PM
old motorhead's Avatar
old motorhead
My guess is that you're going to have enough power to have a whole lot of fun with your Vette. Be careful and enjoy it
Old Aug 15, 2015 | 09:01 PM
Arctic Vette
Oh btw removing restrictor wont cause issues. Except youll be at full 3.25 powa!
Old Aug 15, 2015 | 09:04 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
If more power is an issue.. then, yes
Old Aug 15, 2015 | 09:07 PM
Arctic Vette
I doubt he will complain about that..
Old Aug 15, 2015 | 09:23 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
What size pulley did your kit come with Chokeu?
Old Aug 15, 2015 | 09:24 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Hope not
Of course.. more power always carries some risk, something to keep in mind
Old Aug 15, 2015 | 09:54 PM
Chokeu's Avatar
Chokeu
3.25 came with the kit.
Old Aug 15, 2015 | 10:20 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That seems to be the norm...
I haven't figured out why mine came with a 3.5" instead of the 3.25". I guess Matt was afraid I'd blow something up
Old Aug 15, 2015 | 10:36 PM
Arctic Vette
U want mine? I got a spare
To S/C Install complete!!
Old Aug 15, 2015 | 11:00 PM
Xtremespeed's Avatar
Xtremespeed
From: The only state to ever kick another country's ass! TEXAS
The only issue I see with the restrictor out, is do you have enough fuel? Most people are running at least bigger injectors and some are running another fuel system. Several are still running factory pumps with the bap though. Can't wait to see what kind of numbers you get. Taking mine on Thursday.
Headers, Meth, No restrictor. I think enough fuel will be the only issue keeping you short of 700hp. I expect you'll max the 60#'s.
Old Aug 15, 2015 | 11:10 PM
StingrayRebel
it will probably depend on how meth reliant his tune is... I made a little over 700 with a 255 in tank pump, hotwire harness, bap, 60lb injectors, and meth... duty cycle was 71% but my tuner suggested not pushing it any more than that as far as fuel goes so I added a secondary pump to give me some more room
Old Aug 15, 2015 | 11:26 PM
Xtremespeed
That's a good point. I probably over did mine slightly so it wouldn't really be meth dependent, but that's definitely an option.
