Pulled the trigger..(ECS)
AND the check engine light came on with a bunch of codes today. All catalyst codes and one evap. So im assuming they forgot to delete the rear O2s that I dont have haha. Driving back up there in the morning.
I have a zr1 map sensor but they still tuned it via MAF... Is there any real difference or gains to be had on tuning MAF vs Speed Density?
Makes me wonder if they used the proper data for the ZR1 MAP sensor, amongst other things. While you don't "need" to change the sensor like you did, it's nice for the ECU to be able to see boost and properly calculate fuel flow when there's boost pressure in the manifold. Your tuner needs to manually activate that feature in the tune file, though.
My stock cammed LS3 runs quite smooth in pure MAF mode. My intake is pretty similar to the stock unit, though, so maybe that helps. I've been meaning to play around with SD, but I really have no reason to. Your bucking/surging could be related to a number of things, really.
And I can't remember if this was mentioned, but do you have a wideband? If not, you should. That and the ability to log should be requirements to owning one of these cars, IMHO.
Regardless... I think we all can agree there shouldn't be any surging on a stock cam'd car
With as much time as it's taken me to get the tune right on mine.. I wouldn't say bad things about the shop yet. Give them some time to try to make it better.
Mine was tuned by Matt@FSP who's more than reputable. SD just made the car drive better. Every car is different but pre methanol just LT headers and ECS1500 he ripped on a MUSTANG dyno 574 / 532 on my C6. Matt doesn't try to over push a car but certainly gets a lot out of a little bit of mods.
The maf readings are very scattered on a constant RPM run. The tuner said he is going to reach out to ECS about some potential fixes... Showed me the datalog of the maf readings from 7-22 all while at a constant rpm. So I guess ill just wait to see what ECS says to the tuner. Basically saying there is nothing he can do with the tune to fix this...
It would be cool if an ECS rep got in here with his thoughts. Not a huge issue, but I'd like to be able to happily drive my car when im not racing around... Daily Driveability is not the greatest.
Adding a honeycomb prior to the MAF will likely help
SD would obviously get rid of using the MAF so that would take care of it too
Here's the thread https://www.corvetteforum.com/forums...d-effects.html
If anyone wants the strong one I bought to try I'd sell it for $50. I'm probably going to get rid of the MAF altogether at some point.
See what ECS says first. Maybe there's something else that could be causing it that they know of. I've already given you my suggestion about adding a honeycomb, but at that point I'd probably just do SD and be done with it honestly.
What was up with the evap code? Hope they didn't just change it to "no error reported".
Speaking with many tuners over the years, some that insist on tuning MAF have told me that if they see inconsistent MAF signals, all it take sometimes to correct it is just a slight turn to the upper charge pipe and re-tighten.
Which would explain why some see it and some do not.
I hope that helps.
I hope that helps.
Hey Doug,
Did that shop ever reach out to you? I want to get this straightened out whether it's adjusting the pipe, or switching to the SD tune. I just wanna make sure I approach it correctly with the tuner. I'd rather not take it in and complain then somehow manage to get a blown motor haha.
quality of the tuner is EVERYTHING, i've had a lot of cars and a handful of built LS cars fbodys, c5s, c6 etc tuned by everyone in my area who does LS tunes at one point or another and it is the single most important factor in these cars hands down. it's amazing the difference in driveability with my current tune vs. past tunes from other shops.
THIS!!!!
OP if you try to go around that, you'll ended up pissed, with more money waisted before going back for SD tune. What Chris is doing for you is awesome, if that ain't some great technical supports i dont know what it is!!! Props to ECS
I also bought a ECS kit black can't wait to get into the Fl game . I bought my from TPS motorsports thanks mike hopefully receiving it soon.
