C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
problems with ECS install
Old Nov 15, 2015 | 10:13 PM
russ472's Avatar
russ472
Originally Posted by schpenxel
Yeah its a tight fit.. I bent some of the oil lines a bit to help not squash it as bad but it still has stuff pushing on it. I doubt it will make much difference.
Which injectors? I can send you the base file Matt sent me if you have HP Tuners. You can copy the fuel injector data over. That's about all you need to get it started with the larger injectors.
I do have Hp tuners, but don't have any experience using it yet, other than copying my OEM file and sending it to matt. He emailed asking if I was going to run the stock MAP or the ZR1 MAP. I replied the ZR1 and he hasn't got back with me.
If you could help me out with that, it would be greatly appreciated.
The injectors are the ones that came with the basic kit.
How low do I need to keep my RPMs until I get the tune, injectors and Bap taken care of?
Old Nov 15, 2015 | 10:16 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Just stay out of boost and you should be fine.. I ran mine like that for a little while
What year is your car? Pm me your email
Old Nov 15, 2015 | 10:25 PM
russ472's Avatar
russ472
pm sent
Old Nov 15, 2015 | 11:02 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I didn't get a PM?
Old Nov 16, 2015 | 11:03 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Looks like this has been handled, if any further assistance is needed please email us.
Old Nov 16, 2015 | 04:05 PM
russ472's Avatar
russ472
thanks Doug. The guys on the board are extremely helpful.
Old Nov 16, 2015 | 04:43 PM
DOUG @ ECS's Avatar
DOUG @ ECS
They sure are, I was in WV this weekend with zero cell service and Wifi was two towns away, it's nice to know the forum regulars are there to help!
Old Nov 16, 2015 | 06:33 PM
russ472's Avatar
russ472
can anyone tell me what this hose hooks up to. It originally was plumbed into my intake tube before the throttle body.
Old Nov 16, 2015 | 06:34 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Remove it. Catch can will connect where it used to connect to the valve cover (or hose will go from valve cover to air filter for clean air in, I can't remember which, but I know the stock plastic hose needs to go)
Old Nov 16, 2015 | 08:48 PM
GeneSch's Avatar
GeneSch
I would replace that balancer ans send it back and get the one that moves the 2 ribs out.
Old Nov 16, 2015 | 08:58 PM
russ472's Avatar
russ472
Too much of a pain in the a$$ to do that at this point. Im gonna run it and see what happens. I bought a laser belt alignment tool before doing this. after adjusting the tensioner, everything is lining up well.
Old Nov 16, 2015 | 08:59 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You have the same one as me. I've been running it for a year no problem... It should be fine--just won't work if you ever want to go 8 rib. It's fine for 6 rib and still better than the stock one
