Solid mounts
Dec 21, 2015 | 12:01 AM
Solid mounts
After doing some reading I see some recommend solid motor mounts and diff mounts? Does anyone on here have actually solid block mounts? If so how do you like them? I don't mind the vibrations
Dec 21, 2015 | 11:07 AM
I have solid motor mounts and love them didnt add any vibrations imo...
Dec 21, 2015 | 11:11 AM
Quote:
Originally Posted by
Arctic Vette
Which ones do you have? Ill probably end up making my own.
Dec 21, 2015 | 02:27 PM
Dude_man
C6 Aluminum Motor Mounts
Solid billet aluminium motor mounts.
CNC machined from 6061-T6 aluminium and assembled with grade 8 hardware. Total weight assembled is 1.05lbs.
I think you have to call them because I dont see them for C6 anymore but im pretty sure they are same as C5 i paid $100 shipped.
http://www.levelzeromotorsports.com/...210b3b03accdf2
Dec 21, 2015 | 02:30 PM
Arctic Vette
Sweet I was gonna make a set like that, it'll cost me about $15. What do you have for tranny mounts?
Dec 21, 2015 | 02:51 PM
Dont have upgraded tranny mounts.. Maybe ill consider them after you make them..
Dec 21, 2015 | 03:12 PM
Arctic Vette
I have something in the works. If all goes as well ill be selling them. They will be similar to the pfadt
Dec 21, 2015 | 03:20 PM
Looks like an easy mod i overlooked.... Most likely will do after new year..
Dec 21, 2015 | 03:47 PM
solid motor mounts coupled with rubber diff mounts puts a lot of stress on the bell housing. Keep an eye out for cracks on the bell housing.
Solid/Solid will have a little vibration around 2-3k.
Dec 21, 2015 | 03:56 PM
Louis Gigliotti
Have you personally had solid/solid? If so, did you like it? Less wheel hop? I don't mind the vibration
Dec 21, 2015 | 04:08 PM
Dude_man
It wasn't a deal breaker. If you run cats, I'd not recommend them. I liken it to that. The harhness is there, but it's only really evident at idle, when stationary.
Dec 21, 2015 | 04:25 PM
Louis Gigliotti
No cats, single rear mounted turbo car. Thanks for the info.
I talked to rpm and they said the same thing and told me to change my rear control arm bushings to poly or spherical.
Dec 21, 2015 | 04:53 PM
Dude_man
Plz post pix and your install here of your custom mounts when done, tks bro.
Dec 22, 2015 | 10:09 AM
Arctic Vette
Will do
Dec 22, 2015 | 11:01 AM
