C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost a Pump question
Old Jun 21, 2016 | 04:49 PM
Jose2SS's Avatar
Jose2SS
Default Boost a Pump question
If you have a boost a pump installed and it stops working, will the pump shut down? or just drop the pressure? Please let me know as I am trying to identify the pressure drop on my car fuel pulp at 5800rpm's.
Thanks!!!
Old Jun 21, 2016 | 04:55 PM
CI GS's Avatar
CI GS
The BAP is just a voltage booster, so if it fails to switch on, then your fuel pump will still run on the normal ~12 volt supply that it would see at idle, off-boost, etc., so the pressure will drop if you're running at a power level that consumes fuel beyond the capacity of the stock un-boosted pump.
Old Jun 21, 2016 | 05:01 PM
Jose2SS's Avatar
Jose2SS
Super, thanks, I thought that the boost a pump will cut the fuel pump power if the fuse burns.
Old Jun 21, 2016 | 05:14 PM
CI GS's Avatar
CI GS
If the FP fuse burns out, the pump will shut down. Not so sure about the BAP fuse. I think that will only cause the BAP to fail to switch on, at least on my car, which has the Racetronix harness. This concerns me too, to be honest. IMV it would probably be better if it shut down completely rather than causing the motor to run lean without you knowing, just because the BAP isn't activating!
Old Jun 21, 2016 | 06:27 PM
Unreal's Avatar
Unreal
Yes a blown fuse will mean no power and car won't run.
Old Jun 21, 2016 | 06:52 PM
CI GS's Avatar
CI GS
Thanks. Good to know.
Old Jun 21, 2016 | 07:30 PM
Jose2SS's Avatar
Jose2SS
Yes, good to know. Has this ever happened to anyone here? the BAP blown fuse or damaged?
In order to not be with the scare of that, I ordered a Z06 fuel pump, that will take care of it without the BAP.
Old Jun 22, 2016 | 01:40 PM
Ancient Warrior's Avatar
Ancient Warrior
Yes, I had the same issue when the fuse in the racetroinix harness blew the car stopped.
To Boost a Pump question
