C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Head studs
Old Oct 19, 2016 | 03:03 PM
Ant-Man's Avatar
Ant-Man
Default Head studs
I see a lot of people installing S/C and turbos themselves, how many of you guys are studding the heads while you're at it? I'm thinking about doing it while I'm in there. Plan on running a 3.4" or 3.6" to get 10-13# and around 700rw
Old Oct 19, 2016 | 05:10 PM
westtexasbuff's Avatar
westtexasbuff
Always good to do. I'm using the knockoff ARP ones torqued to 80 ft lb.
Old Oct 19, 2016 | 07:36 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I don't remember many people around here doing it for the 700rwhp range.. seems more common ls1tech where they take a truck block and go for 800+
Old Oct 19, 2016 | 07:51 PM
chpmnsws6's Avatar
chpmnsws6
If the heads are off, yes.
Old Oct 19, 2016 | 09:09 PM
Unreal's Avatar
Unreal
Like they said, if heads are off go for it, but no reason to touch anything for <850rwhp. I wouldn't crack a factory head seal unless absolutely needed.
Old Oct 20, 2016 | 07:35 AM
slow goat's Avatar
slow goat
I was swapping the heads and Cam while installing my blower. So naturally, it made sense to go ahead and do it then.
Old Oct 20, 2016 | 07:55 AM
Steve Haefner's Avatar
Steve Haefner
2018 C6 of Year Finalist
If the heads are off at a minimum use ARP bolts vs the factory (easier to torque) I never will never trust myself to do torque angle.
Old Oct 20, 2016 | 11:49 PM
Ant-Man's Avatar
Ant-Man
Yea my heads cam off and put some truck heads on there, I'll be studding it and upgrading the valvetrain and cam at the same time. Thanks
Old Oct 21, 2016 | 10:55 AM
Ls240sx's Avatar
Ls240sx
No matter what aftermarket studs you use, china or arp, make sure the bolt holes are clean and not full of water. There are plenty of articles online about china studs breaking and threads stripping. I would attribute 90% of these to not getting all of the water out and vapor locking. I personally use ARP whenever I can BUT in my latest motor I tried the china ones just because with a setup that has made over 1000. So far.. so good.
Old Oct 21, 2016 | 01:09 PM
Unreal's Avatar
Unreal
Should be using the ARP thread cleaner too before putting anything in.
Old Oct 21, 2016 | 01:40 PM
SlowBusa08's Avatar
SlowBusa08
Yup, chase them and clean them before putting studs in.
To Head studs
