C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Flex Fuel Conversion
Old Nov 21, 2016 | 12:46 PM
aAZz's Avatar
aAZz
Yea thats what I plan on doing. Maybe theres some black friday deals that will get me a discount lol
Old Nov 24, 2016 | 12:29 AM
TWS Racing's Avatar
TWS Racing
Dsteck kit from Dedicated Motorsport is what I run. I wouldn't mess around with piecing a kit together to save a few bucks. Not worth the hassle IMO. Install is straightforward and simple. Only thing that takes time is removing your passenger side front fender to pin the wire to the correct connector pin slot going to the ECM. Tuning from a competent tuner is also required.
Old Nov 24, 2016 | 02:22 PM
Mrbluedevil88's Avatar
Mrbluedevil88
Just checked their Facebook page. 15% off their flex fuel kits start tomorrow
Old Nov 24, 2016 | 06:03 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I'd jump on that
The tuning part is easy
Old Nov 25, 2016 | 12:48 PM
aAZz's Avatar
aAZz
just went to their website and i still don't see that on there?
Old Nov 25, 2016 | 01:35 PM
Mrbluedevil88
Old Nov 25, 2016 | 01:39 PM
aAZz's Avatar
aAZz
i'm just going to call in. They only have it listed with injectors for 1200 and i dont need any injectors
Old Nov 30, 2016 | 11:19 PM
KM177122's Avatar
KM177122
Any luck? I know I went with the Fore Fuel System with flex fuel sensor and it seems to work pretty darn well. A little more pricey than $1200 but not that much more.
Old Dec 1, 2016 | 05:22 AM
GeneSch's Avatar
GeneSch
I called on Monday and the deal is only if you buy with over priced injectors. They offered zero discount on their sensor??
How do you like the Fore system? How was the install? Any pics? I'm on the fence with ordering that set up or just doing the A@A external pump with the return line. I like the idea of not messing with the stock pump and tank internals.
Old Dec 1, 2016 | 11:11 AM
Unreal's Avatar
Unreal
Fore system is very very nice, but any intank setup is a pain in the ***. Nothing picture worthy as it is all in the tank. Nothing to see.
The injectors are not overpriced at all.
Old Dec 1, 2016 | 12:21 PM
TWS Racing's Avatar
TWS Racing
In progress pic of my Dedicated fuel system install. 2010 ZR1.
Old Dec 1, 2016 | 03:15 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Pesonnally I would go with Dave's kit, but if you want to do it yourself racetronix is currently having a sale on flex fuel sensors.
Old Dec 1, 2016 | 03:26 PM
  #33
Unreal's Avatar
Unreal
Or just get one from your local discount GM dealer.
Old Dec 1, 2016 | 04:45 PM
  #34
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Or Amazon Prime if you're as lazy as me
Old Dec 1, 2016 | 05:25 PM
  #35
GeneSch's Avatar
GeneSch
then I just need to get a connector, wire it to the coil power and run the signal wire to the computer correct?
Old Dec 1, 2016 | 07:33 PM
  #36
Unreal's Avatar
Unreal
And fuel connectors, and lines, and tune, etc.
Old Dec 1, 2016 | 07:59 PM
  #37
GeneSch's Avatar
GeneSch
What I meant was there is no need to spend $400 for a C6 specific plug and play unit if If I'm just going to put it after the regulator in the return line? So I can order a GM sensors and connector and make it suit what ever set up I end up with. I'm doing research now to see If I will piece a system together or just order one.
Seeing different locations others put the sensor. I agree that it should go after the regulator so it's getting a true reading of what the injectors see. If you put it on the secondary pump side. It will only have fuel flow when the secondary pump is on. If you stop at the gas station and get gas. It won't be able to see the change and mixtures until you activate the pump. Then the system can't truly work as intended.
To Flex Fuel Conversion
Old Dec 1, 2016 | 09:27 PM
  #38
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yes to first question
And I have several of the connectors laying around for pulling power from a coil if you want something that will just plug in, just let me know
Old Dec 1, 2016 | 10:15 PM
  #39
KM177122's Avatar
KM177122
The Fore Fuel system is nice. I'm still working through some kinks with it but it's a nice setup. I suppose it depends on the route you want to go. I'm happy with the tank internal setup as it's nice and hidden but I understand what you are saying.
Old Dec 2, 2016 | 11:59 PM
  #40
aAZz's Avatar
aAZz
Yea no haven't done anything yet. Like u said they wanted injectors as well and I can get some 80# way cheaper so might just piece it together
