C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Can Dashlogic display injector duty cycle?
Old 04-27-2017, 04:03 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Are you in the screen for dic / hud or calculated PID's?
The format I posted, i.e. pid(1008)/60000 * pid(10) / 2 * 100
is what you should use in the calculated PID section, then use that PID on one of the pages for DIC or HUD. Spaces or not shouldn't really matter
This shows how the setup basically works. It's for a wideband but the steps are the same, except use this formula instead of the one in the pictures that was for a wideband
https://www.corvetteforum.com/forums...post1593643488
Old 04-27-2017, 08:33 PM
Wilkinshc
Wilkinshc's Avatar
If you want the other bank to display, you would have to substitute 1008 to 1009.
Old 04-27-2017, 08:41 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
That formula appears correct. I'm not going to be the redneck revving up his corvette in the drive way but at idle it matches HP tuners
Old 04-27-2017, 08:53 PM
ls1wolf
ls1wolf's Avatar
So I literally copied and pasted what you used (changed to the PID numbers) but all it shows inthe DIC is the actual formula...??
Old 04-27-2017, 08:54 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Probably should start with this.. You're putting the formula in the wrong place I do believe.
Old 04-28-2017, 07:18 AM
ls1wolf
ls1wolf's Avatar
Thanks... I'll try that tonight.
I was going into the "custom" section, when you select the page. Then going under the "advanced" area and entering the formula.
Old 04-28-2017, 08:48 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Yeah that's the wrong place
You have to create an injector duty cycle PID first by going under "calculation PID's". That's where you'll want to enter the formula I posted yesterday along with the number of decimal places, units (%), etc.
Once it's created then you go under DIC or HUD, advanced, and then use that new PID. I can post some screenshots if you need help
I tested it this morning and the formula I posted earlier did seem to work correctly
The following 2 users liked this post by schpenxel:
ls1wolf (04-28-2017), Wilkinshc (04-28-2017)
Old 04-28-2017, 03:10 PM
Wilkinshc
Wilkinshc's Avatar
I used it and works. Under "calculation Pid's" I have one using 1008 and one using 1009 (both banks). No decimals. On the HUD in advanced I added the %. At first, I put the injector pulse with next to that reading and it seemed inline.
Thanks for everyone's help!
Old 04-28-2017, 03:22 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
You could always average inj PW for bank 1 & 2 if you really wanted to. Either way they're going to very close to the same at WOT anyways
Old 04-28-2017, 05:29 PM
Wilkinshc
Wilkinshc's Avatar
Yes, your right. 1008 seems to be the same or 1-2% more duty cycle. Most be air flow or sensor variance.
Old 04-28-2017, 07:15 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Fuel trims are probably a little higher on whatever bank is reading higher
Old 04-29-2017, 03:49 PM
ls1wolf
ls1wolf's Avatar
OK, so tried it and let it idle.. Shows 2.2 (ish) at idle. LS9 injectors with heartbeat blower and cam.
Havent driven the car to see but that's what I show using the formula above. Quick little rev, the numbers shows 8~9ish.
Sound about right?
Old 04-29-2017, 03:50 PM
  #33
schpenxel
schpenxel's Avatar
St. Jude Donor '15
That's about right. Mines about 1-2% at idle but I'm running ID1000's and e85
ls1wolf (04-29-2017)
Old 05-05-2017, 11:18 AM
  #34
Seadawg
Seadawg's Avatar
Thanks guys, learn something new every day out here
Old 05-10-2017, 05:11 PM
  #35
Xtremespeed
Xtremespeed's Avatar
Location: The only state to ever kick another country's ass! TEXAS
Since you all are already on the subject, does your odometer function in dashlogic work? I am using the pre mapped pid for odometer, and all I get is 0.0 mi. I'm assuming I need to make a new pid based on speed sensor input.
Old 03-12-2019, 08:42 PM
  #36
Silver c6 z-51
Silver c6 z-51's Avatar
Hey schpenxel, can you take a screenshot of your calculated PID for this option, thank you
Old 03-13-2019, 10:03 AM
  #37
schpenxel
schpenxel's Avatar
St. Jude Donor '15
I didn't drive that car today. What you are trying to do?
To Can Dashlogic display injector duty cycle?
Old 03-13-2019, 10:45 AM
  #38
Silver c6 z-51
Can you confirm my settings for injector duty cycle, it did save correctly so I believe the format is correct, thanks.
Old 03-14-2019, 02:18 PM
  #39
schpenxel
schpenxel's Avatar
St. Jude Donor '15
I can check mine in a little bit--remind me if I don't respond in the next few hours
Old 03-14-2019, 02:53 PM
  #40
Silver c6 z-51
No worries, I was able to get to my car started today and confirmed the injector duty cycle is working properly. Thanks for the help and your posts
Quick Reply: Can Dashlogic display injector duty cycle?
