Just fine. Only seen 108-109F but running nice and cool. A/C works great, no issues. Suppose to be 120F on Monday but I'm in Boston so no way to test it.
I Like. Mounting the fans down low pushes a lot of air under the car and around the bottom of the motor. Where did you buy the fans from?
DJ
I bought the fans from DeWitts and had them build the shroud to fit their cut down radiator. I had them mount them as low as possible without going off the core to clear the blower.
Since they are the Nuova fans, then yes they need their own harness, temp sensor, etc. My single 17" came with everything needed. Just install temp sensor, run power/ground, and done. Only thing I need to go back and do is wire in the AC override since AC doesn't work until car gets to 170, but no big deal.
My 17" setup was ~$650ish, so I wonder what that dual 11" and if it actually works better. One reason I like the 17" is it leaves a good amount of the radiator unshrouded so on highway/etc air can pass through easy, since fan doesn't have a speed shut off function.
yeah no vent holes on the shroud would prob run hotter at highway speeds, but should work great for low speed cooling. My car runs great on the highway with the Dewitt's and stock fan and non existent shrouding lol and sucks for low speed. This looks to be a good alternative to d3 fans if the pricing is right.
Got them installed today and drove about 40 miles home and never got above 196 with the ac on, even though it was only 92 outside its still a win. Yesterday it was over 210 sitting in traffic. I'm sure once I add an oil cooler it will be even better.
Just picked up an ECS Supercharged Grand Sport 2 months ago. Already preparing to upgrade the cooling system as the guy said it ran ~225+ out in Florida and our summers out here in AZ are way worse. Good read in this thread
I run stock rad.. with a 180 thermstat i hover around 175 on my idle temps and under 200 on driving now.. and i was well over 230 in the summer forged stroked blower car
I'm was 25 degree here yesterday.
..how long were you idling it ?
prob 15 mins.. i just used crappy wire when i did it.. i ordered basically the wire they use for running lines from alt to battery and starter to battery style wire.
Has anyone used a mark VIII fan on a C6? It seems like it would fit on a stock radiator and airflow rating is much higher than our stock fans. I know Dewitts did a comparison back in the day that said the mark VIII is very similar to a dual spal 11". I have a Taurus fan on my 1981 vette and it moves way more air than my stock Z06 fan.
My current 2010 z06 with ECS 1500 kit gets to 245F easily in traffic with the A/C on. I am looking for a cheap alternative to the other fan options on the market today.
