C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost Gauge Source Nightmare
Old Mar 12, 2018 | 03:57 PM
Sergio7's Avatar
Sergio7
Default Boost Gauge Source Nightmare
Seems like a very common thread in every single platform. Well my boost gauge reads no boost, just more vacuum when i get into higher rpm. I have no boost leaks & my BOV is working properly. I have tried with two gauges & they both work since i blew little air into them with a compressor & they would register psi. Any possible fixes? I'm getting my boost source from the manifold. (T'd off with the BOV)
Old Mar 12, 2018 | 06:07 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Sub'd
Old Mar 12, 2018 | 06:27 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Are you WOT and at higher RPM's when it keeps reading vacuum?
Old Mar 12, 2018 | 09:25 PM
StingrayRebel's Avatar
StingrayRebel
try running it separate from the bov instead of tee'd into the same line
Old Mar 12, 2018 | 09:42 PM
Daddy Freeman's Avatar
Daddy Freeman
Are you trying to check it just by reving it up? If so, you won't see boost because you are not under a load. I am in now way trying to insult you. I say this because my dumb butt learned that the hard way.
The only other thing that I can suggest is to check you Blow Off Valve and make sure it is closing instead of staying open.
Old Mar 12, 2018 | 10:42 PM
HouseS2k's Avatar
HouseS2k
Mine is Teed off the brake booster. Works great.
Old Mar 13, 2018 | 12:33 AM
c6 monkey's Avatar
c6 monkey
Same here, off the booster, no issues
Old Mar 13, 2018 | 03:07 AM
Sergio7's Avatar
Sergio7
Well only downside to that is that i have an ecs e85 fuel system & my hobbs switch get's vacuum from there
Old Mar 13, 2018 | 03:08 AM
Sergio7's Avatar
Sergio7
That's what i thought, but if i'm building boost wouldn't it atleast register some instead of staying dead 0?
Old Mar 13, 2018 | 06:23 AM
lt1z's Avatar
lt1z
Vaccum block is the answer. You need a better signal with multiple things running off boost/vac .
Old Mar 13, 2018 | 08:47 AM
gameover4's Avatar
gameover4
agreed here, if not just put another T into the brake booster
Old Mar 13, 2018 | 01:26 PM
Unreal's Avatar
Unreal
Should be fine where its at. Do a pull and see. Like they said above, reving it in neutral won't show much of anything.
Old Mar 16, 2018 | 07:12 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
You won't be able to get a boost reading just free revving it at idle. Need to be driving under load enough to force the BOV closed then you will start reading boost.
Old Mar 18, 2018 | 10:17 AM
IansInGarage's Avatar
IansInGarage
The real problem is you haven’t got Car off jack stands isn’t it. Everyone does this pretty much on their first boosted gauge install. Yes you should be reading zero. Go drive around block.
To Boost Gauge Source Nightmare
