C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Afr question...
Old May 16, 2018 | 12:04 PM
  #61
Kingtal0n's Avatar
Kingtal0n
Originally Posted by BLOWNBLUEZ06@RKTPerformance
Because a vacuum signal is not needed.
If he has a tune-able ECU it can surely take advantage of the vacuum referencing capability of a regulator. It is only 1 line to hook up and he can drop vacuum for idle/cruise significantly lowering the fuel pressure for those times.
This will:
1. extend fuel pump life
2. keep fuel cooler
3. fuel systems components will last longer in general
4. reduce current draw of fuel pump
To me, this^^^ is all 'needed'.
Old May 16, 2018 | 02:16 PM
  #62
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You should probably let GM know all these improvements they could get from putting vacuum referenced regulators back on their cars
/sarcasm
Old May 16, 2018 | 02:17 PM
  #63
stevieturbo's Avatar
stevieturbo
You could also say a boost signal is not needed either.
Doesn't make it a good way to do things.
There really is no reason to reference anywhere other than the intake manifold. There are no benefits to taking the reference from elsewhere.
Old May 16, 2018 | 02:20 PM
  #64
stevieturbo
/sarcasm
Some modern GM cars and some others run closed loop pump control.....so in essence, yes they are referenced to load....just not mechanically via an FPR.
People, manufacturers etc do different things for different reasons.
Old May 16, 2018 | 02:32 PM
  #65
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
You could say it, but it wouldn’t make it true.
How so? How about the vehicle owner is currently tight on money and his IDC is too high or maxed out because of the boost he’s running? Let’s say 28psi boost and not boost referenced for instance. Now, as you well know, he has only 30psi across his injector. Boost referencing gives him the fix he needs for now without having to spend money he doesn’t currently have or want to spend.
How about another one of my customers running 40psi boost? Yes 40. And you’re going to say for the sake of your argument that a boost reference signal isn’t needed? I know you to be a smarter cat than that.
The customer happens to want to tap into his charge pipe for a signal. So what? Get the benefits of boost referencing and everything else remains as GM designed it as far as fueling is concerned.
There certainly is a benefit from getting the boost side of it and absolutely no harm in not getting it on the vacuum
side. Never thought of it? Okay, fine, but think about it. It has all the upside that the car owner desires with none of the downside.
Old May 16, 2018 | 02:33 PM
  #66
Supporting Vendor
See, I knew you were that smart!
Old May 16, 2018 | 02:37 PM
  #67
Kingtal0n's Avatar
Kingtal0n
/sarcasm
I want to believe their decision in this case has something to do with regulator placement near the rear of the vehicle, near the tank. For whatever reason (probably engine bay clutter and unique access) an under-car replaceable, serviceable filter-regulator was established, and the idea of running a vacuum signal from the engine to the rear of the car was laughable. So they argued the system was worth more than the fuel system parts that needed to be replaced sooner, and that someone could just add a real regulator up front (I mean, duh you notice right away when you go to build the car) if they recognized the need for proper reference in the fuel system easily enough. As even if they gave us one we would still probably seek to replace it at a level due to flow orifice diameter, anyways.
It isn't a problem for GM dealership when serviceable parts fail in our cars, and need to be replaced. Especially parts that need a couple hundred dollars to get going again, like timing belts, brake pads, clutches, fuel pumps. I think we've all tried, in one way or another, to get our car manufacturers to implement systems which last longer.
Just because it isn't there, doesn't mean we won't benefit from it. If you bought a car with no A/C would you immediately suggest that I let the manufacturers know "hey guys you forgot / need A/C". Or a sunroof. Or a battery life extender. Or a spare tire. Or a fuel system stress reliever.
Old May 18, 2018 | 08:45 PM
  #68
C U IN REARVEIW's Avatar
C U IN REARVEIW
[QUOTE=schpenxel;1597211604]You should probably let GM know all these improvements they could get from putting vacuum referenced regulators back on their
