C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
How to attack Meth dependent SD
Old Jun 27, 2018 | 10:44 AM
1966427's Avatar
1966427
Default How to attack Meth dependent SD
Doug of ECS told me and I've read multiple posts stating that if you tune completely meth dependent and the meth ever fails for whatever reason then you go so lean it shouldn't damage the motor. Any of you guys who tune your SC setups Meth dependent and are more knowledgeable than myself, how do you go about attacking the vve table? Maybe my meth is coming in too fast but it goes rich quickly. After playing around with the vve table it seems difficult to get it to match that curve, especially after calculating coefficients. In other words how can I pull 10-15% fuel at 120-125 kpa without completely skewing the rest of the table? Any insight or advice would be appreciated. I'd love to see a screenshot of someones vve table that has this worked out.
Old Jun 27, 2018 | 10:47 AM
1966427's Avatar
1966427
I should mention I have a 2013 grandsport w/ ECS kit and meth. I am just running low boost right now(6lbs). I want to get the fueling correct before I start adding boost.
Old Jun 27, 2018 | 10:57 AM
Silver Bullet C6's Avatar
Silver Bullet C6
St. Jude Donor '10-'11-'12
Have you asked this question in the "Tuning" section also?
Old Jun 27, 2018 | 10:59 AM
1966427's Avatar
1966427
I have not, I thought I might get more responses from some of the FI guys in here since this is directly related to the sc meth setups.
Old Jun 27, 2018 | 11:21 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
If you switch to the 2bar OS it will make this easier for you since the rest of the table won't be forced to fit the equations.
You can export your existing vve table with columns matching whatever you'd end up with in the 2bar os, paste it into excel and transpose and you've got your new ve table in the 2bar os format.
Old Jun 27, 2018 | 11:40 PM
1966427's Avatar
1966427
I am set to 2 bar by altering the Map axis, and have extended the spark table air mass axis. Is there any additional benefit to going to 2bar os?
Old Jun 27, 2018 | 11:44 PM
sevinn's Avatar
sevinn
I figured you were, but what I was getting at is that since the 2bar os provides a real table you won't have other areas getting messed up when you fit the coefficients. I'm not suggesting you switch I was just providing a solution to the question you posed.
Old Jun 27, 2018 | 11:45 PM
1966427's Avatar
1966427
So on the 2 bar os when i make adjustment they stay as they are, No need to calc coefficients?
Old Jun 27, 2018 | 11:46 PM
sevinn's Avatar
sevinn
Yep
You do lose a good deal of resolution though.
1966427's Avatar
1966427
Yeah that would be nice. I'll have to look into that. Thanks
Old Jun 28, 2018 | 06:19 PM
stevieturbo's Avatar
stevieturbo
Your post sounds confused.
If you tune an engine to be dependent on meth and the system fails, you will blow **** up.
You're stating it will do no harm....it will do harm.
Old Jun 28, 2018 | 07:12 PM
theandrewo's Avatar
theandrewo
I've read what he is talking about as well, but I think the only way this would work is if the ECU detected that the meth has failed under boost and cuts fuel completely in order to prevent lean conditions?Otherwise a lean condition would indeed blow up your motor, right?
Old Jun 28, 2018 | 09:23 PM
Unreal's Avatar
Unreal
Works fine. Lean is bad, so lean it doesn't run doesn't hurt as it can't run.
Old Jun 28, 2018 | 11:18 PM
1966427's Avatar
1966427
Yes running lean will hurt the motor. The theory is that if you run so lean when meth fails that it runs so shitty it will be obvious something is wrong. From what I understand extremely lean is better than slightly lean. As unreal said if there is not enough fuel to run then its much harder to damage the motor. My question now is if i tune for .75-78 lambda on a single 10gph nozzle will the engine run that much leaner if the system fails? Seems like It would put me much closer to the dangerous lean zone as the car goes rich by 10-15% with the meth. So you reverse that math it would put me at roughly 13/1 or .89 lambda.
Old Jun 29, 2018 | 04:59 AM
stevieturbo
A powerful boosted engine will break **** at 13.0:1 under load unless it's some **** hot fuel you're using.
You'd need to be cutting pretty much all fuel, or at least some 50%
Old Jun 29, 2018 | 09:45 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Incorrect in my experience, I have had several customers make multiple passes without meth (why I don't know) once the car runs so lean it simply doesn't create enough heat to melt things.
Exact;y, the car falls on it's face and you know something is wrong. Add in the IAT safety and it literally feels like you shut the engine off. Lift the pedal and it runs perfect again.
I hope that helps, but this is breaking my cardinal rule of never discussing tuning on forums, so I'm out! Best of luck with it.
Old Jun 29, 2018 | 12:09 PM
Unreal's Avatar
Unreal
Like when I had a fuel pump die. It would go 17:1, pop and stutter. Didn't hurt anything. 13:1 bad, 17:1 doesn't even run and you let out.
I've already told the OP how to handle this, either through adjusting the axis on the VE tables or using PE. Up to him how he wants to take it from here.
To How to attack Meth dependent SD
Old Jun 29, 2018 | 01:18 PM
1966427's Avatar
1966427
Unreal did you send a DM? I never got the explination you are talking about.
Old Jun 29, 2018 | 01:25 PM
Unreal's Avatar
Unreal
Hmm, typed out a response, but maybe it never went. My phone does that sometimes.
I'll resend later when I get a chance.
Old Jun 29, 2018 | 01:53 PM
1966427's Avatar
1966427
