V-15 testing the right way at East Coast Supercharging!!
I
I got to rub one at LS fest. It was pretty.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,091 Likes
No pricing as of yet that I know of.
Yes and no, it bolts right onto the brackets the same, but spacing to the radiator is closer so some kind of rendition has to be made there. Also, the size of the ducting is bigger so that has to get matched up as well. It didn't take long for us to get into a C6, but some changes do have to be made. Also an Air to water intercooler is needed, I did race with this blower on Saturday with an air to air, but it is greatly limiting it's potential, to say the least. Realistically though if you are going to use this blower then there is probably not that much stock about your car anyway.
Quiky One (05-13-2019)
I had one time shot and I wanted data more than ET, I crept out of the hole with a 1.7 60" and ran a low 9. Nothing impressive as far as ET goes, but again, not what I was after. I didn't want to take a chance of blowing off the tires and not getting a clean graph. Our new dyno should be here any day now so that will ease things.
vettemayhem (05-16-2019)
jason
That data would very, very valuable! Thanks Doug.
Any updates?
We were making pulls and were going to test it at a SlipStream event, but on one of the last dyno pulls one of the Bosche 2000 injectors stuck wide open. Even though it was only idling it hydro locked the engine and bent a rod. Can't make these things up, but while the engine is being rebuilt we have sent it off to Supercharger outlet and Performance in NC to test on one of their cars. We should have results very soon, then we will get another one in the car here.
Creamo3 (10-11-2019)
#33
Received 1,195 Likes
St. Jude Donor '15
Did you get any decent #'s in before the injector went to **** or no?
