Problem with Viking coilovers .. Please help
The more I drive it, the more the suspension feels like I was riding in a logging truck !
My next step is to ****-can the 500 Lb/in springs on the rear coilovers and get a set of 400 Lb/in replacement springs for them.
I have the compression set on #3 and the rebound set on #5 .... I am going to change that to #1 compression and #3 rebound and see what it feels like.
I kind of wish I had just left the rear suspension alone and bought a pair of those aftermarket lowering bolts (or just cut the rubber pads off my stock bolts) ... that would have more than likely lowered the rear enough on the car.
After all the dicking around that I’ve had with these coilovers, my recommendation to anyone who wants the best performance out of their car would be to leave the stock springs alone and just install the Viking D/A smooth body shocks.
The real magic of the Vikings is their valving and you really need a good DA shock to get the best performance out of your car, at least on the drag strip.
And I don’t know how ordering them from CPR would eliminate the problem with the spring unseating at full drop, unless they order the shorter coilover as I noted already. And no matter what you do, if you screw the spring seat down low enough, it will hit the axle.
The thing is that most people just put them in and forget about them and not notice
I would bet good money that anyone that has the stock to 1.5” drop Vikings will see have the same unloading of the spring at full drop, especially if they are using the typical 500-650# springs.
This is the same kind of thing I heard when I had the problem with the front coilovers hitting the UCA at full drop, and that it might be an alignment problem, etc.
But here’s the thing: I took pictures and documented what I was saying. And if I hadn’t bothered to check for that myself, I wouldn’t have found that problem and I could easily be saying mine has no issues too.
Because the truth is that 99% of the time no one will notice or bother to check, and not notice any issue.
Joe does these all the time, has none of the issue people ordering from elsehwere run into. So I don't know what he is doing, but nothing but happy customers without all these issues. Mine don't hit the axles, don't have droop issues, no problems at all, verified MANY times.
Nope, because I called Joe, said order me the coilovers you have put on 50+ cars without issues, and a few days later they showed up at a great price.
Or maybe he didn't install the coilovers. You just ordered the coilovers from Joe and they were delivered to your door ... then you installed them.
If that's the case, was there not a part number on the box or on the invoice?
Throw me a bone here ....
I do know there is no generic part number, and you have to talk to him about what you want. Stock height? Lowered 1"? Slammed? Road race? Street? Drag Race? etc etc etc and then he orders what he knows works. They are not just something you pick out of a catalog.
Yes, I could’ve left them alone, but I was trying to get my car to hook better on a very challenging track surface. I could’ve (and should’ve) left the stock springs on it too. Hell, I could’ve left my car stock too, or just got someone to build me a badass ride and post pictures of all the parts it has on it, but where’s the fun in (and learning from) that? Such is the nature of these things: We experiment with aftermarket enhancements and report the outcome on here. Such, I thought, was the very reason for the existence of these forums, no? Otherwise we would just be posting pictures of the cars somebody else built for us, right? I know I learnt a lot on here from you already, so there’s that, too.
The front coilovers on my car admittedly have a bastard part number, but they do look identical to the ones on your car. They could be longer, for all I know, but one thing is for sure, they hit the UCAs badly, and it wasn’t an alignment issue, because with the control arms adjusted all the way out, they still hit, badly.
The car transfers, hooks and runs much better now with the stock front spring and the naked Viking Crusader shocks than it ever did and possibly could have with the front coilover springs on it (and I tried 4 different rates and lengths too).
The one problem, albeit a negligible one, that I have with the rear coilovers on my car is that with the Carlyle spindle, the UCA also hits the spring. I don’t know if yours does that, and to be honest, if I didn’t notice the little nicks on my springs, I wouldn’t have spotted that problem myself. So, I simply put some limiter straps on it. Which, by the way, Viking instructs you to do for all it’s coilovers, so that in the event of violent unloading (although it is hard to imagine how that would happen in the rear) the top doesn’t get ripped off the shock. Go figure.
As far as spring rates go, that’s like just about everything else, including shock settings: it depends on what you’re doing with the car. As far as I know, Ron (the OP) wants to drag race. So, I’m happy to share with him my honest opinion based on my own experience, since that is all I can do honestly.
And I do honestly think he’s worrying too much about the rear coilover spring getting slack at full droop, because, as I said before, that will only happen when he jacks the rear up or if he takes the car hill-jumping or something, in which case a limiter strap is a very cheap fix.
That’s all I have on the matter. Not really trying to step on toes or trying to **** on the tree or anything. I’m just trying to help him out because I already kinda screwed him up with advising him to get the 500# springs, since everyone I know said that you need a ~650# coilover spring in the rear of a C6, which always I thought was the case, until I tried 650# springs myself and it failed, and then I discovered Borg’s table, which I posted above, which helped me understand why it didn’t work.
It should be noted that it differs substantially in terms of spring rates shown in their older catalog (which is also still on their website), and that Viking themselves now recommends significantly lower spring rates for their “DH” (600+HP) and “DL” (<600HP) drag packages, with 450# springs for the former and 400# for the latter.
Note the last 4 digits in the part number, which denotes the spring rates for each.
1.) 8" x 2.5" coil springs in the 400 Lb/in variety.
2.) Hyperco Helper Springs, P/N CS100 (4” L)
3.) Hyperco Spring Dividers, P/N 18DS100
4.) Set compression on 2 and rebound on 3
5.) Got an alignment
I
The car rides really nice now and there is no slop in the coilover springs when the car is jacked up and the rear wheels hanging.
The only problem now is a slight clunking-like noise coming from the rear when riding over a rough road ... I got under the car with all weight on the wheels, and nothing is hitting under there ... springs are not hitting against the axles or against the rear upper A-arms. I can't figure out what is making this noise ... shock piston travel is not at it's max travel either.
Attachment 48334317
I car rides really nice now and there is no slop in the coilover springs when the car is jacked up and the rear wheels hanging.
That noise might just be when the helper springs “stack”, since they’re going to do that very easily, especially with those low shock settings.
I would just have thrown a 9” spring on it, TBH.
I glad that you’re happy with it, though.
Maybe try increasing the compression setting to 5 or 6 (and maybe the rebound to 6 or 7) to slow down the rate at which the shock moves and see if that dampens or eliminates the noise.
You know, I also had that slight clunking sound with the original 500 Lb springs and before I installed the helper springs ... so this has been there ever since removing the leaf spring and initially installing the coilovers.
I will be damned if I can figure it out
That may be the culprit.
