C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Another cam thread- custom cam
Old Feb 6, 2022 | 10:04 PM
old motorhead's Avatar
old motorhead
Originally Posted by Plmcrzytn
Is PatG good at recommending cam
profiles?
yes
Old Feb 7, 2022 | 09:49 AM
CI GS's Avatar
CI GS
profiles?
Everyone seems to be happy with him. Happy enough to pay him $50 to spec a cam. But it’s not really black magic, and like I said before, tuning is the key to getting any decent sized cam to idle properly. I would put the money towards a decent cam kit.
Here’s what I would suggest, along the lines of what Turbo6TA suggested already, developed by a reputable C6 centri blower package vendor/installer, used in probably hundreds of C6 vettes, I’m sure any competent tuner will be able to dial the tune in easily:
https://briantooleyracing.com/a-a-su...-32030163.html
Old Feb 7, 2022 | 12:50 PM
Plmcrzytn's Avatar
Plmcrzytn
Pat spec'd the cam I listed. I have a very reputable high end installer installing it and a tuner that they use tuning it.
Old Feb 7, 2022 | 06:32 PM
Plmcrzytn's Avatar
Plmcrzytn
“””””The cam will give you a 40-50rwhp gain on motor alone. The supercharger determines how much power you'll make. If you add a cam, the engine breathes better and boost will drop. If you were making 8lbs of boost with the stock cam, you'll make 6-7lbs with the PG cam. If you change pulleys to get your boost back to 8lbs, then you can expect to see around 650rwhp with this cam and your mods”””””
This was sent to me regarding my combo potential. 650 seems high to me, I was thinking around 580. Am I way off?
Old Feb 7, 2022 | 07:17 PM
old motorhead
That would be my guess with an M6 transmission and boost in the mid to high 8's. Maybe a little optimistic through an A6. Pat doesn't miss too many times though so I'd hate to bet against him. I'd probably choose something between Pat's cam and the one Sammy mentioned. If cam Cam Motion is grinding it, I wouldn't be afraid of going over .600 lift either. With the narrower LSA and same advance, the intake valve closes quicker helping low end power. I don't mind a little chop though. The cam Pat specced for you ought to be a real sweetheart with very little chop.
Old Feb 7, 2022 | 08:23 PM
m60gov20's Avatar
m60gov20
Only thing better than a little chop is a lot of chop! Lol
Old Feb 7, 2022 | 09:58 PM
Plmcrzytn's Avatar
Plmcrzytn
I love a great chop but I’ve always always, loved a sleeper even more. I’m leaving the NPP mufflers on too
Old Feb 9, 2022 | 11:00 PM
Plmcrzytn's Avatar
Plmcrzytn
Does the TSP #199-ISSPACPOL660SpringKit sound right for the cam I mentioned originally?
Old Feb 10, 2022 | 07:32 AM
old motorhead
I use BTR springs. I have not had good luck with Tx Speed springs and was less than satisfied at how they handled things. If you gave me Tx Speed springs, I wouldn't use them. I used them once on top of a very mild cam and had a broken spring after just a few miles. The springs were installed by them on their heads. I've used several sets of BTR springs and have never had a problem. Here's the BTR springs I use: BTR PLATINUM LS DUAL SPRING KIT - .660" LIFT - SK001 (briantooleyracing.com)
Old Feb 10, 2022 | 10:25 AM
Plmcrzytn's Avatar
Plmcrzytn
Thank you my friend
Old Feb 10, 2022 | 03:18 PM
Plmcrzytn's Avatar
Plmcrzytn
Thank you my friend
Anddddd theyre out of stockkkkkkkkk
Old Feb 10, 2022 | 03:38 PM
SpinMonster's Avatar
SpinMonster
profiles?
PatG is awesome with cams.
Old Feb 11, 2022 | 10:58 AM
  #33
Pekka_Perkeles's Avatar
Pekka_Perkeles
So true.
It would also be interesting to see the correlation between a cam size, a particular tuner and how soon the car is in for sale -section of this forum.
Old Feb 11, 2022 | 11:54 AM
  #34
SpinMonster
Originally Posted by Pekka_Perkeles
So true.
I think that all the time. Some think going huge on a cam makes all sorts of power but in reality, a 230/234 makes within 5 or 10hp of the nastiest cam you cam fit in there. What you give up for that tiny power increase is manners and being able to live with it. The LS3 makes great power with a moderate cam. After sale regrets would as you imply, be high.
Old Feb 11, 2022 | 11:57 AM
  #35
SpinMonster
By the way, anyone with a poor idling car can come by my house in Colorado Springs and I can help you smooth it out. Im not trying to make money here. Labor is free. Just making friends.
Old Feb 11, 2022 | 03:30 PM
  #36
Plmcrzytn's Avatar
Plmcrzytn
I just ordered the cam Pat Recommended
Old Feb 11, 2022 | 04:37 PM
  #37
Plmcrzytn's Avatar
Plmcrzytn
I really wanted a 3/4 bumpstick with 4'' headers and a double pumper but he said that may affect fuel mileage
To Another cam thread- custom cam
Old Feb 11, 2022 | 05:30 PM
  #38
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Yup ... back in the day you could opt for a "Full Race" cam or the infamous "3/4 Race" cam
Put a set of "Solids" and "Pop-Up" pistons in the engine and don't forget the "Cherry Bomb Glasspacks" and 4.11 gears . . .
Old Feb 14, 2022 | 04:00 PM
  #39
SpinMonster
Originally Posted by Turbo6TA
"Cherry Bomb Glasspacks" . .
Hollow tubes. lol
Old Feb 15, 2022 | 01:13 PM
  #40
Plmcrzytn's Avatar
Plmcrzytn
so the 3/4 cam has .750 lift?
