C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Hp expections?
Old Oct 4, 2023 | 10:08 PM
KingC6's Avatar
KingC6
Default Hp expections?
Currently building my car to be very competitive now at days. I have a 416 ls3 with A&A ysi kit on secondary drive with dsx aux fuel pump attached to a bap with 1050 cc injectors and meth kit. I'm trying to see what would be my ball park numbers before I get more goodies. Also running stock fuel pump and have e85 flex fuel kit, fbo and tsp blower cam
Old Oct 5, 2023 | 10:46 AM
m60gov20's Avatar
m60gov20
What pullies are you running?
Old Oct 5, 2023 | 10:49 AM
KingC6's Avatar
KingC6
3s on a secondary 8 ribs
Old Oct 5, 2023 | 06:01 PM
thehulk's Avatar
thehulk
Fueling limitations factored in 900 +/-
Old Oct 5, 2023 | 06:28 PM
KingC6's Avatar
KingC6
that's what I was thinking, and low tq around 800
Old Oct 5, 2023 | 08:15 PM
Al_Scrap's Avatar
Al_Scrap
+-900whp with a lower, proper fuel system and 10.5 compression engine.
Old Oct 6, 2023 | 01:09 AM
KingC6's Avatar
KingC6
Yeah in the future like probably next year I'll look at the fore system for fuel or at the thr hellcat in tank
Old Oct 11, 2023 | 02:46 PM
rlane5's Avatar
rlane5
KingC6 you're going to need bigger injectors with that 416 and YSI. I have a 403 with a A&A YSI with 95 LBS Deatswerk injector and an Aeromotive 340 fuel pump and was running out of injector and fuel, I just put Bosch 210 LBS (2200cc) with a TI hellcat pump. I have both the AM pump and hellcat pump with a Holley Terminator X Max turning the second pump on at 1 LBS of boost
Randy
Old Oct 11, 2023 | 02:50 PM
KingC6's Avatar
KingC6
Randy
how much you making rear hp that is
Old Oct 11, 2023 | 07:06 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Ran an almost identical setup to what you are describing but on a 402. It made 10008 rwhp. 1000 cc injectors were plenty on mine running 94 and meth.
Old Oct 11, 2023 | 07:07 PM
m60gov20's Avatar
m60gov20
Yhats a lot of power!
Old Oct 12, 2023 | 09:57 AM
rlane5's Avatar
rlane5
With my 95 LBS injector, I data log a hit and the duty cycle was 126 and the AFR was 15.0 without the TI pump. I have a Holley Terminator X max on my Vette, and in the VE table it showed that I would be out of injector with 95 LBS The 210LBS /2200CC is over KILL but I don't want to keep buying injectors. I put the injectors in last week, I have a friend on the forum (DRIVER 456) that had the same problem. He told me that it won't be enough injector and showed me on the terminator X. I am not running Meth but I am running E85. I have not dyno it yet, I'm trying to sort out any issue I might have before I go to have it Dynoed
Randy
Old Oct 13, 2023 | 12:18 PM
LS YEET's Avatar
LS YEET
was that in a rocket ship?
To Hp expections?
