C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
A&A prep
Old Jan 29, 2024 | 02:11 PM
Vetta_loca's Avatar
Vetta_loca
Default A&A prep
So in the next few months I'll be getting an a&a supercharger for my c6 base what are some things I should upgrade to handle it? Currently plan on new radiator, fuel pump, spark plugs, bigger stall, oil and tranny cooler, better suspension and brake, better tires and considering the hood. How does the 6l80 handle 650whp any advice is appreciated. I do also have a tuner that's very knowledgeable with ls and 6l80 but I don't wanna bug him to much so trying to narrow down my questions
Old Jan 29, 2024 | 03:15 PM
glennd's Avatar
glennd
Given the amount of labor in changing the torque convertor it would be a good time to upgrade the 6L80
Old Jan 29, 2024 | 03:16 PM
Vetta_loca's Avatar
Vetta_loca
what would I do to upgrade it?
Old Jan 29, 2024 | 04:06 PM
thehulk's Avatar
thehulk
For 650rwhp? lol
Old Jan 29, 2024 | 04:23 PM
jdw456's Avatar
jdw456
The a and a kit will come with plugs. Id suggest a fuel system depending on you power goals. But again that's user preference on boost pump ( included in kit ) or Fore system etc. Best to talk with Josh or Andy direct and they will lead you the path of success based on your goals.
Old Jan 29, 2024 | 05:49 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
Give us a call to discuss if you haven't already.
Josh 805-278-4107
Old Jan 30, 2024 | 09:27 AM
Vetta_loca's Avatar
Vetta_loca
Originally Posted by thehulk
For 650rwhp? lol
yeah what do i do with the transmission tried finding stuff for building it but it's all pretty vague
Old Jan 30, 2024 | 10:03 AM
NM C6's Avatar
NM C6
I recentl did the same kit. Josh at A&A is very helpful. i would recommend doing the trunion kit on the rocker arms, possibly blower cam, high volume oil pump and double valve springs. I did long tube headers and cat delete also. Mine is 645 bhp on stock lower end and stock trans. Plan on doing converter soon though.
Old Jan 30, 2024 | 10:05 AM
Vetta_loca's Avatar
Vetta_loca
pretty sure I did the trunion kit when they swapped my cam already have a stage 2 btr kooks longtube with catless and varam cai.
Old Jan 30, 2024 | 10:36 AM
NM C6's Avatar
NM C6
Nice. I didn't see that in your description. I have same set-up. I woul recommend mt et street tires. I was spinning anything under 50mph now it hooks even from a dig.
Old Jan 30, 2024 | 10:37 AM
Vetta_loca's Avatar
Vetta_loca
I'm thinking those for that reason 1st is already useless
NM C6's Avatar
NM C6
Are you doing the installation yourself ?
Old Jan 30, 2024 | 10:53 AM
Vetta_loca's Avatar
Vetta_loca
nah I travel for work year round I got a shop that does amazing work plus id be lying if i said i wouldnt **** it up lol
Old Feb 4, 2024 | 03:11 PM
thehulk's Avatar
thehulk
As long as your transmission is healthy all you'll realistically need is a trans cooler and a proper tune.
Old Feb 5, 2024 | 10:32 AM
SpeedyWs6's Avatar
SpeedyWs6
Agreed, my 100k mile 6l80 held 770 just fine. It showed signs of not liking 800 plus as much. When I pulled the motor I dropped the trans and had it done by Century. I wouldn't bother with the trans below 700.
To A&A prep
