C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Plug gap?
Old May 21, 2024 | 08:14 AM
BlackFya's Avatar
BlackFya
Default Plug gap?
I have the Tr6 plugs. What should they be happed at on an ls3 with v3ti, 3.8 pulley. No meth or E85 tune
Old May 21, 2024 | 01:39 PM
streetking408ys's Avatar
streetking408ys
Assuming the engine is stock with stock compression, how much boost? I'd expect the short answer to be as much gap as possible up to the factory specification without running into boost induced "blow-out"
Longer answer: Once you're pressurizing the cylinder enough to induce ignition issues, gap down .002" at a time until it's tamed. All within reason assuming no other contributing factors like a weak ignition system, faulty parts, low voltage, oil/blowby buildup on plugs etc.
Old May 21, 2024 | 04:05 PM
Josh@AandASuperchargers's Avatar
Platinum Supporting Vendor
.035" gap
Old May 21, 2024 | 07:21 PM
BlackFya's Avatar
BlackFya
Default Thanks
Thank you @Josh@AandASuperchargers
To Plug gap?
