Meiere Electric water pump, high flow idler style, fits GM LS1 through LS8
Meziere Electric water pump, high flow idler style, fits GM LS1 through LS8
I have a brand new Meziere elictronic water pump. These pumps retail for $760 so own this one for much less and it is still brand new in box i only opened it to take a couple pictures. This water pump fits ls1's threw ls8's if your not sure it fits your car just ask and i can do my best to find out.
I am asking $600 Shipped
I am located in Rensselaer Falls NY
here are the details straight from there site,
WP319S - Street Style Electric Water Pump
Innovative design makes for an easy installation. Unbolt your factory pump and bolt on an easy 11-14 horsepower with our street style water pump. An idler is incorporated onto the pump so your belt routing remains in its stock configuration. American made with quality far superior to any other performance aftermarket company, we build our water pumps with pride right here in the USA. Don't be mislead by inflated flow numbers and competitors' outlandish claims. Our 300 series pumps move more water and produce more pressure than any other electric pump on the market. That means better protection for your high horsepower, high demand engine! Our 2 year, unlimited mileage guarantee and full satisfaction money back guarantee should convince you that buying Meziere is buying value!
This water pump model features:
- Fits GM LS-1 through LS-8 engines
- Idler design lets you keep all of your serpentine belt driven accessories
- Suitable for street or drag strip use – 3000+ hour life expectancy
- Show quality black anodized finish
- Standard motor provides 55 gallons per minute free flow rating
- Ports provided for heater and bypass
- Outlet fitting, heater and bypass fitting included
- Stainless steel large diameter main shaft with high performance ceramic seal
- Technical Specifications:
- Finishing The System: This pump is supplied complete with gaskets, hardware and fittings. No additional items should be necessary.
- Amperage draw: Under normal use the pump will draw 11-12 amps.
- Overall Height Dimension: The standard pump is 7.8" long from the mounting surface to the tip of the pump.
- Pump Weight: This application weighs 14.9 lbs.
