Brake Pads
Old Apr 19, 2005 | 06:03 PM
QWK C6's Avatar
QWK C6
Default Brake Pads
got some chrome wheels and some red calipers for the Z-51
and before i put them on
i wanna see what i can do about the brake dust and the annoying brake squeal
what can i do and where can i get a good deal
thanks
Old Apr 19, 2005 | 06:37 PM
HalM's Avatar
HalM
You can get brake pads that don't stop as well...pretty weird on a sports car isn't it? Go for more of the ceramic type pad...
Old Apr 19, 2005 | 07:07 PM
C6FirstVette's Avatar
C6FirstVette
Here is my choice...AutoX and tracked many cars with these pads and stellar performance...of course IMO>>>
Old Apr 19, 2005 | 09:07 PM
AU N EGL's Avatar
AU N EGL
the Ceramics will reduce dust or change it to tan dust and take longer to stop your car. Ceramics are fine for normal street driving, you just have to get use to the little extra distance to stop your car.
Old Apr 19, 2005 | 10:23 PM
elmagoo's Avatar
elmagoo
Didn't someone mention earlier that there's a spray or coating you can apply to the pads that will reduce the brake dust?
Old Apr 20, 2005 | 01:56 AM
SA734's Avatar
SA734
How about Hawk HPS brake pads? Anyone know if they will do the job and fit the Z-51? Another question for the mechanics: I got the calipers off the front, but how do you remove the pads from the calipers? The rear pads just slipped off?
Old Apr 20, 2005 | 08:27 AM
AU N EGL's Avatar
AU N EGL
I used Hawk HPS one weekend. They had more dust then an Oklahoma dust storm. worst dusting pad I have ever used. stopping was not that good either. The C5 Z06 pad fits nicely and works far better. The actual caliper is the same on the C5 and the C6 so pads are interchangable.
any spray coating on the brake pads will make the car NOT stop as well. same with ceramic pads. Tan dust and less stopping power so it takes longer to stop your car.
Performace cars need performace brakes = brake dust. No two ways around it. Wash the wheels and car more often. a good wax, Zaino or what ever makes the dust come off quicker too.
When you have the caliper off the pads just fall out. You will need to push the caliper piston back in to get the pads back in place. Use two C-clamps, one on each pistion to push them back in.
Old Apr 20, 2005 | 10:09 AM
SA734's Avatar
SA734
Tom, the rear pads did just fall out, but the front pads won't come off the caliper. I have the caliper off and the pads are still in. Someone else said you have to pry them off, but I don't wont to damage anything. I even tapped lighty them with a rubber hammer and they don't budge. What's the secret?
The car only has 1,900 easy miles on it.
Old Apr 20, 2005 | 03:52 PM
elh0102's Avatar
elh0102
Get a bigger hammer. Seriously, the factory C6 front pad backing plate has some adhesivie gunk on it, and it takes more force than seems appropriate to break it loose, especially the first time. I just bought some factory C5 ZO6 pads, and they don't have anything like that on them; don't know why it's there, maybe an anti-rattle tactic.
Old Apr 20, 2005 | 04:02 PM
AU N EGL's Avatar
AU N EGL
There you go elh has taken his off a few times.
Sometimes you just have to use a BFH
Old Apr 20, 2005 | 10:20 PM
GarryZR1's Avatar
GarryZR1
Call Parts Bob at Ficthner Chevrolet in Montana
They have the new C6 ceramic pads that dust 10% of the stock ones.
They will stop just as good, but not for competition or track days. Good for auto-xing.
To Brake Pads
