Alignment specs?
Old Apr 19, 2005 | 07:53 PM
haljensen's Avatar
haljensen
Default Alignment specs?
Anybody have the stock specs for wheel alignment on the C6? Caster, Camber and Toe, Front and Rear? The shop doesn't have the C6 in the files yet.
Search was no help.
Old Apr 19, 2005 | 08:19 PM
elh0102's Avatar
elh0102
I don't know if you have strictly street use in mind, or some track stuff. I recently had mine set up at neg. 1.5 front and neg. 1.2 rear camber, about 1/8 toe in rear, and 1/16 front, all the caster available. This might be a bit aggressive for pure street, but my tire life is limited by track schools, and they will never see 10K miles anyway.
Old Apr 19, 2005 | 09:27 PM
sallen619's Avatar
sallen619
I've been trying to find out the same info for 3 months now. I've had no luck. I hit a pot hole in the rain and through my alignment out. Once a wear pattern starts in a tire...it's over.
Old Apr 19, 2005 | 09:33 PM
NextOne's Avatar
NextOne
Doen't the dealer have this information? My C6 is scheduled for an alignment job next week because of excessive rear outside tire wear.
Old Apr 20, 2005 | 01:08 AM
haljensen's Avatar
haljensen
Th dealer undoubtedly has the info but doesn't share with the private alignment shops. Hunter hasn't released the info to the private shops yet.The guy I'm going to does mostly competition alignments and corner weighting and doesn't have specs on the C6.
Old Apr 20, 2005 | 01:52 AM
SA734's Avatar
SA734
According to Fichner Chevrolet the service manuals should arrive next week. I reserved a set a week ago and should have it within two weeks if they are on time.
Old Apr 20, 2005 | 08:31 AM
AU N EGL's Avatar
AU N EGL
Ask this question over in "General - Autocross & Roadracing". The gear heads over there know what those specs are and are quite freindly to guys who dont race their cars.
gear head?? Hey I resemble that remark.
Old Apr 20, 2005 | 10:51 PM
Anthony01's Avatar
Anthony01
Search was no help.
Here you go guys
Wheel Alignment Specifications
Suspension
Front
Camber: -0.45° ± 0.60°
Camber Cross Tolerance: ± 0.60°
Caster: 7.90° ± 0.60°
Caster Cross Tolerance: ± 0.60°
Total Toe: +0.10° ± 0.20°
Steering Wheel Angle: 0° ± 3.50°
Thrust Angle: --
Rear
Camber: -0.45° ± 0.50°
Camber Cross Tolerance: ± 0.50°
Caster: --
Caster Cross Tolerance: --
Total Toe: 0.00° ± 0.20°
Steering Wheel Angle: --
Thrust Angle: 0.0° ± 0.20°
That is straight from GM, I also threw in the trim height if anyone needs it
Trim Height Specifications
RPO
Service Preferred
Tolerance
Metric
English
Z Trim Height - Coupe
FE1 (Base)
46 mm (1.81 in)
39.6-52.4 mm
1.56-2.06 in
FE2 (F55)
46 mm (1.81 in)
39.6-52.4 mm
1.56-2.06 in
FE3 (Z51)
45 mm (1.77 in)
38.6-51.4 mm
1.52-2.02 in
Z Trim Height - Convertible
FE1 (Base)
45 mm (1.77 in)
38.6-51.4 mm
1.52-2.02 in
FE2 (F55)
45 mm (1.77 in)
38.6-51.4 mm
1.52-2.02 in
FE3 (Z51)
45 mm (1.77 in)
38.6-51.4 mm
1.52-2.02 in
D Trim Height - Coupe
FE1 (Base)
122 mm (4.80 in)
115.6-128.4 mm
4.55-5.06 in
FE2 (F55)
122 mm (4.80 in)
115.6-128.4 mm
4.55-5.06 in
FE3 (Z51)
121 mm (4.76 in)
114.6-127.4 mm
4.51-5.02 in
D Trim Height - Convertible
FE1 (Base)
121 mm (4.76 in)
114.6-127.4 mm
4.51-5.02 in
FE2 (F55)
121 mm (4.76 in)
114.6-127.4 mm
4.51-5.02 in
FE3 (Z51)
120 mm (4.72 in)
113.6-126.4 mm
4.47-4.98 in
Document ID# 1618420
2005 Chevrolet Corvette
Old Apr 20, 2005 | 11:33 PM
haljensen's Avatar
haljensen
Anthony01; Thank You Sir! You are a gentleman and a scholar.
Old Apr 21, 2005 | 07:00 AM
Anthony01's Avatar
Anthony01
Glad I could help
Old Apr 21, 2005 | 10:27 AM
Lee6's Avatar
Lee6
what are the "trim heights"?
Old Apr 21, 2005 | 11:36 AM
Anthony01's Avatar
Anthony01
Trim height is a predetermined measurement relating to vehicle ride height. Incorrect trim heights can cause bottoming out over bumps, damage to the suspension components and symptoms similar to wheel alignment problems.
The Z height dimension measurement determines the proper ride height for the front end of the vehicle.
The D height dimension measurement determines the proper ride height for the rear end of the vehicle.
Hoped that helped
To Alignment specs?
