Vortex Rammer
Old May 18, 2005 | 09:10 AM
seymour's Avatar
seymour
Mikey, I do not know what the car dyno'd at before the Vortex - also, the Corsas could have helped with the HP - also, 367.5 was on an auto which people are saying get better results from the Vortex (if true?).
Old May 18, 2005 | 09:49 AM
mikeyc6's Avatar
mikeyc6
Originally Posted by c6nut
I returned the Vortex I purchased. I lost 3 HP on the DYNO. I think it was way to much for no gain. Fit and finish was terrible then but I saw that there were modifications for the newest product. I will do the Callaway product this summer.
I'm going from memory here, but aren't you the one who had trouble with the check engine light after the install? I remember at the time that there was some question about whether or not those issues were affecting performance and allowing the Vortex to operate properly (and therefore receive the full gains).
Edit: I went back and looked it up. The model you used was the old one with the vent hose upstream to the MAF which caused A/F ratio problems. The only reason you didn't get the check engine light on the dyno and got it two hours later is because the computer had not yet settled on LTFT values. Bottom line is that you dynoed the car when it was being crippled by this problem which I'm sure is why you saw no gain (or a loss). Not your fault obviously but that issue has been fixed on the current Vortex by simply correcting the routing of the PVC vent. Fit and finish were no problem on the unit I ordered a week or so ago.
Mike
Old May 18, 2005 | 01:41 PM
Chrisbequick's Avatar
Chrisbequick
Originally Posted by yellow1
What's so special about the Calloway and Vortex that they have not encountered OR were able to overcome this issue? Did they do some "magic" with the computer?
There's no magic to it. Look at the intake designs. The Callaway and Vortex leave the MAF in the stock location. Halltech puts the MAF way up front with no screen. There is no pipe or screen to straighten the air flow through the MAF. The MAF sees turbulent air and doesn't understand what's going on. As a safety measure it pegs the fuel trims rich.
It's pretty common sense. Other bolt-ons increase airflow through the engine (and therefore the MAF) without freaking out the computer. Even other intakes have no problem. It's obviously a problem with Jim Hall's design, and the only major difference is the location of the MAF.
FWIW- I rarely recommend taking the screen out of a stock GM MAF. I run a stock screened MAF on my Camaro, and it makes 720 at the flywheel.
-Chris
Old May 18, 2005 | 09:40 PM
c6nut's Avatar
c6nut
Mike
You are correct. I think Ernie fixed the problems after I had so many problems.
