Removing front plate frame
Old May 23, 2005 | 04:39 AM
stingrik's Avatar
stingrik
Default Removing front plate frame
Has anyone had expereince with this? Will it pull the paint off or damage the paint? Any experience or advice would be appreciated.
Old May 23, 2005 | 09:46 AM
montanacowboy's Avatar
montanacowboy
I removed mine....I used wd40 and a hair dryer.......no problem at all....it's double stick...just go slowly and it comes off easily
Old May 23, 2005 | 08:02 PM
Arthur6's Avatar
Arthur6
When I picked up my car (C6), it had the front plate holder installed. I told the dealer I woun't but the car with the holder in place. (Sales guy said it was a federal law, ha ha). I didn't budge. The service guy came up, I told him I wanted him to pull it off so he'd damage the paint if it happened.
He pulled HARD, with his foot against the car, it came off, he removed the glue with some WD-40, no problem.
All is well...
Old May 24, 2005 | 10:16 AM
stingrik's Avatar
stingrik
Thanks for the input.
Old May 24, 2005 | 10:26 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
patience, a nice day, and no interuptions. take it slow, use a little bit of heat (try to make it feel like a warm summer day), a little glass cleaner or alchohol (remember little bits), get your rag wet. work it with your finger nail, take it slow. patience.
that is once you have the holder removed from the double sticky, use a putty knife or simliar item and more or less cut the bracket from the tape - the braket side, you don't want to do it on the car side or you may damage the finish.
Old May 24, 2005 | 12:05 PM
C5-BRUCE's Avatar
C5-BRUCE
The answer to this question is similar to how you remove BSM's. Yes, a hair drier is good, but this time of year just park it nose first into the sun. Pull up the frame as much as you can, and slide some dental floss down to the glued surfaces. There are three of them. Work the floss back and forth until it separates. WD-40 works well to remove the remaining glue. I have pictures of the underside of the mounting plate if anyone wants them - I'd post them here but I don't know how?
Bruce Miller
c5bruce@adelphia.net
Old May 31, 2005 | 02:48 PM
iluvmyc6's Avatar
iluvmyc6
walk up to the front of the car, put your hands on the front plate bracket, and pull. No hair dryer required. Two sided tape ripped in half, leaving the rubber in between the glue mostly on the front plate bracket. Grab both sides so when the first of 3 attachment points break, you don't scratch the paint on the other side of the car.
I just did mine. I'll get something that looks better than the stock one once I find the one I want.. I'll keep the plate in the cat with the bracket attached in case I get stopped for the meantime.
To Removing front plate frame
