C6 Date Code
Old Jun 13, 2005 | 09:10 AM
tleeker's Avatar
tleeker
8th Gear
Default C6 Date Code
Would someone breakdown the C6 VIN. I am looking for the date code to see where my C6 falls for the damper bolt problem cut-off date of 341. Preparing to take the Vette on it's first long drive -1,900 miles. I appologize in advance if this has been covered before . I searched a halve dozen ways and couldn'ed find it in past posts.
Old Jun 13, 2005 | 09:37 AM
Vette_DD's Avatar
Vette_DD
There's no date code in the VIN. However, you can find the month and year in the door frame of your car.
This is an example of a VIN # for a 2001 Corvette Convertible:
1 G 1 Y Y 3 2 G 1 1 5 1 0 0 0 0 1
There are 17 characters. Starting with first character on left the codes are:
1. "1"= Built in US
2. "G"= General Motors
3. "1"= Chevrolet
4. Denotes the car line: Corvette is a "Y" body.
5. Provides more info about the car:
Usually a "Y" but the ZR-1 is "Z"
6. Body style: "1" = FRC, "2" = Coupe, "3" = Convertible
7. Restraint code
8. Engine:
L98="8"
LT1="P"
ZR1="J"
LT4="5"
LS1="G"
LS6="S”
LS2=”U”
9. Random number issued by the computer as a check.
10. Model year:
"B" thru "N" are yrs '81-'92 respectively
"P"='93
"R" thru "T" '94-'96
"V"='97
"W"='98
"X"='99
"Y"='00
"1"='01
“5”=’05
11. Plant: Bowling Green = "5"
12-17. Production sequence number that starts with the #1 for each model yr.
Old Jun 13, 2005 | 10:27 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
http://forums.corvetteforum.com/show...em&forum_id=74
Click on "advanced search", type in key words as "balancer bolt problem", click on C6 General forum and search...more info that you ever wanted to know.
Old Jun 13, 2005 | 11:16 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Slight modification. Position 9 is not random. It is calculated from the VIN itself.
Old Jun 13, 2005 | 12:04 PM
Vette_DD's Avatar
Vette_DD
Does that character have a name?
Old Jun 13, 2005 | 02:35 PM
Brett Hunter's Avatar
Brett Hunter
From what I understand the engine date code of 341 is no longer the cutoff. The new cutoff is VIN's ending in 11039 and under.
As long as the last 5 digits of your VIN are over 11039 you should be okay.
As an example my date code is 336 but my VIN is 11250 and according to GM mine has the fix.
Old Jun 13, 2005 | 02:43 PM
Brett Hunter
Forgot to post this above.
The date code you are looking for is on the engine. The sticker is located on the drivers side above the oil pan. There is another identical sticker located on the rear of the driver's side head. The one on the head can be seen with a mirror. Below are some pictures of the location of the stickers.
Old Jun 13, 2005 | 02:59 PM
Scissors's Avatar
Scissors
Working from memory, I believe it's called the "check digit."
Old Jun 13, 2005 | 06:11 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default That Guy is Sharp
AKA a Check Sum
Old Jun 13, 2005 | 07:18 PM
Scissors's Avatar
Scissors
Originally Posted by JFTaylor
AKA a Check Sum
Damn computer terms.
Old Jun 15, 2005 | 06:18 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Actually an Accounting term, my sharp friend
Old Jun 15, 2005 | 06:34 PM
Scissors's Avatar
Scissors
I wonder which it was first?
To C6 Date Code
