Stinger is in.
I agree that 10 - 20 hp is hard to feel. Keep us posted on how you like it.
and no water fears.
I received an email from a customer that just installed his system and some of the email is not good for Halltech, but the last sentence is, so I'll share the good, the bad, and the better (how to avoid his problem)
Before his quote, our pdf instruction manual is on our front page. We are not a supporting vendor here, so I cannot link to our site in good conscience.
Here is his quote:
" I received the C6 Stinger today and installed it. Everything went okay except for the filter connection to the bridge. I made the marks on the bridge and installed it right on the marks. The problem is when I would tighten it the filter would slide down the bridge until it would come off if I continued tightening it. So I just tried to put it on snug. When I returned from a test run and opened the hood I noticed the filter had came off. I reinstalled it with the bridge a little further in it. This seemed to work better but I have yet to take the car back out. Do you have any suggestions to solve this?
BTW using a G-Tech meter I did run my best ever 0-60 time by .4 on my first try!
Thanks, Brett"
We recommend pre-installing the bridge into the filter until the end of the bridge is all the way in, but NOT past the inner flange. Protruding edges of the bridge into the filter will disrupt the airflow bigtime. Turbulence at the mouth will rob most of the horsepower gains.
I actually put my hand into the bridge and I can feel the edge of the bridge vs. the flange opening and line it up. Mark it for future reference with a felt-tip marker, or just leave it installed.
It is more difficult to install the filter, bridge, and MAF unit into the rubber transistion hose, but you can do it with the help of a screwdriver to guide the rubber opening around the plastic MAF. The hose clamp should not be installed on the end of the rubber hose at that point. Just open it up completely, and then put it around the hose.
One more hint. Push the PCV nipple into the hole only to the first barb.
Again, the nipple will go all the way in, but will disrupt airflow right at the mouth of the throttle body.
Jim
Air fuel ratios of 12:1 instead of 13:1 can somewhat muffler the intake noise. The more air in the swept volume, the more bang.
The firing order of this engine affects the sound output as well.
The problem is, the bellows points downwards, which is nice if you are looking to route water flow. Airflow prefers to "see" where it is going for best results.
We try to keep everything straight, including the airflow to the throttle body.
We have some preliminary test results from a customer that look pretty interesting. Maybe he will share them.
Jim
This just in from one of our customers:
Stock unit
Max Tq 359 ft/lbs
Max MAF Airflow 302 gm/s
Max Air Flow Calculated 33.5 lbs/min
Max IAT 136 F
Min IAT 86 F
Avg IAT 106 F
Stock ran 10 degree above ambient on the road
Stinger
Max Tq 373 ft/lbs
Max MAF Airflow 308 gm/s
Max Air Flow Calculated 33.2 lbs/min
Max IAT 134 F
Min IAT 82 F
Avg IAT 102 F
Stinger ran ambient on the road
Stock unit
Max Tq 359 ft/lbs
Max IAT 136 F
Min IAT 86 F
Avg IAT 106 F
Stinger
Max Tq 373 ft/lbs
Max IAT 134 F
Min IAT 82 F
Avg IAT 102 F
The Min IAT numbers you see on the stock unit was at startup. The IAT on startup with the Stinger was 104 F so the min was actually on the road with the Stinger.
"Hello all, we just had a C6 in the other day with the Dynatech systemaxx and the stock intake system.
The first pull was 345RWHP and then 347RWHP on the next immediate pull. (I let the car decelerate to 50MPH and then pull it again on back to back pulls.)
Next we pulled the stk intake off and put on the Halltech. Took about 15min .....yeah yeah yeah I know it should have taken me about 5 or less. I was fumbling around a bit .... a lil excited like a little girl with new shoes. Next pull 360RWHP followed by 362RWHP.
That's a good solid 15RWHP that you can feel. Great product JIM!!
I am under the belief that in about a 3400lb vehicle it is going to take about 15RWHP to have that SOTP difference.
The AFR was a bit rich up top so we leaned it up and then the next pull we made 371RWHP and 365RWTQ.
I thought that it was a bit odd that these cars made the same power as the other C6 with the same mods. That is quite uncommon because each car is different and the early stages of each motors life can dictate how it will make power later on in its life. I find that the ones that were babied are whimps and the ones that were beaten hard make great power. I compared the 2 curves of the cars with the same mods, pk HP and torque was the same but underneath the curve there was as much as a 10 RWHP difference. There is something to be said about weather and correction factors. One was dynoed in the rain and the other in much hotter air temps. I have never seen an accurate dynojet weather station with the exception of one and been to some 30 er so dynos. kinda makes you wonder huh? Quite often I am a bit skeptical of this mod and that until I do it myself because I know that I do my best to control variables. All in all I was very pleased to see the difference for myself and even more faith in a great product."
Jeremy Formato
We will have some Stingers at Bloomington. We are inside! Stop by and I'll tell you about it in person.
Jim Booth
www.CAU-LLC.com
Where da Pix
