Honker help?
Old Jul 28, 2005 | 11:01 AM
frenchcu's Avatar
frenchcu
Default Honker help?
Trying to insyall Honker and having problems with the dreaded shroud. I have removed 6 pushpins and it is still stuck it looks like there is a silver speed nut holding it down at the bottom. Any ones have any ideas what I have to do.
I am quickly losing it.
Old Jul 28, 2005 | 11:32 AM
frenchcu's Avatar
frenchcu
Okay figured out the screw part. now it is stuck on the passenger side where there is a pin with a sensor holding on to it and I can't seeem to budge that side any suggestions.
Old Jul 28, 2005 | 07:38 PM
BEZ06's Avatar
BEZ06
I just PM'ed you, but It's been a few hours since you posted your question. I hope you've gotten the thing out by now - and back in!!
I think the "pin" on the passenger side you may be talking about is actually the outside air temperature probe.
Unfortunately, I don't have any suggestions. It's just a real PITA to get the shroud out. I think you'll have an easier time getting it back in (at least I did). You sorta know a little better what you're trying to do.
Like I said, I hope you're all done with the whole install by now. Let us know how it went.
Bob
Old Jul 28, 2005 | 07:51 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
A PITA for sure...its very flexable, so bend/twist the heck out of it. Its pretty much bullet proof.
Old Jul 28, 2005 | 08:35 PM
jrjen2's Avatar
jrjen2
My Callaway Honker showed up this afternoon in the mail. I'm going to install it! If you don't hear from me then I just want you all to know that you are the best forum buddies a guy could ask for.
Old Jul 28, 2005 | 10:10 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Good luck. Took me 2 days & 8.5 hrs. Still have scars to prove it.
Old Jul 29, 2005 | 12:01 AM
purple heart's Avatar
purple heart
Default No Problem...
Tell you what I did: read these replys over the past month or so regarding installing the Calloway Honker and tell you what I did-found a local Corvette shop and set the date to have it installed, had it installed today and it took them the better part of 4-5 hours to do. It was their first Calloway but they did a very professional job. It took 2 men to disasemble and reassemble that damn shroud and it was NO EASY TASK. There are push pins (plastic type) everywhere, several wire assemblies that had to be disconnected, and man, let me tell you, unless you have ALOT OF PATIENCE AND TIME AND YOU ARE A PART-TIME CONTORTIONIST, its just not worth the money you spend to pay somebody to do it. They didn't expect it to take this lone so I was just charged a "fair" price of $168.00. I watched do the whole job including installing the pop rivets in and it would have taken me 1 or 2 days of bending, twisting and pulling and plus I didn't have a pop rivet gun.
So, for what it's worth...
Good Luck
Old Jul 29, 2005 | 07:39 AM
cielosf's Avatar
cielosf
Default callaway install
I wore a pair of tight fitting Mechanix gloves for the shroud extracting part. It sure can save your hands when your pushing and bending it. Also nobody factored in the booze bill for all the time it takes to get this thing in and out.
Old Jul 29, 2005 | 11:52 PM
jrjen2's Avatar
jrjen2
Glad that the job is done and over with. It took me most of the evening to do the install and the majority of the time was spent screwing with the shroud. My mechanics gloves were a lifesaver on the 'ol hands.
To Honker help?
