Power Shifting !
Old Aug 27, 2005 | 07:53 AM
cobraq8's Avatar
cobraq8
Default Power Shifting !
What sort of damaged if any could power shifting inflict on a C6 ?
Old Aug 27, 2005 | 09:33 AM
vetteman22's Avatar
vetteman22
set aside a lot of money ,you'll need it sooner than later
Old Aug 27, 2005 | 10:03 AM
AU N EGL's Avatar
AU N EGL
The Termic transmissions were not designed for any kind of powershifting. Many ppl have deistroyed the tranny with too much and too hard of powershifting.
Set aside some money and get a Jeriko staight cut gear tranny if you wan to do a lot of powershifting.
Old Aug 27, 2005 | 10:55 AM
SunsetVette's Avatar
SunsetVette
what type of shifting are you thinking of doing. Im aware of 2 kinds of shifting one is just keeping your foot on the gas and hitting the clutch, or not using the clutch at all. i shift my car, when i race it by keeping my foot on the gas and my car is fine, plus i got warranty
Old Aug 27, 2005 | 11:48 AM
robvuk's Avatar
robvuk
I've been powershifting for 40 years with every manual I ever owned, from the musclecar era with highly modded Roadrunners, Camaros, Corvettes and Challengers all the way through to my C5. Never had a problem. It slams hard but so does dumping the clutch from a standstill. I'm not saying bad things don't happen, just never happened to me. Good luck, have fun, you only live once.
Old Aug 27, 2005 | 12:05 PM
Pio's Avatar
Pio
I bent the shift forks on my 2001 M5 during a private track day at Bakersfeild raceway. Also, you'll hit the rev limiter everytime you shift. I started practicing power shifting with my first 5 ltr LX in 1992. If your heart is set on it, start practicing with part throttle so you can get the coordination for it.
FYI - the M5's tranny would've been over $8K out of my pocket had I not had a great relationship with the dealer.
My experience is that powershifting improves et by around 2/10's.
Old Aug 27, 2005 | 12:07 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
You must be living right.
I have heard of 3 types of shifting.
Power shifting, as I understand it is putting the gas pedal to the floor, keeping it there, while working the clutch and the shifter.
Speed shifting is just that. Speeded up "normal" shifting. Lifting off the gas, hitting the clutch, shifting and then back to the floor with the gas.
The last type of shifting, without the clutch, I have heard of as well. But I have never met anyone who actually does it.
In any event, if you have never powershifted, its probably not a good idea to try and learn how in a 50k+ sports car.
I have heard too, as the original poster above stated, that for a drag racer, power shifting inproves 1/4 mile times by "at least" 0.2 and I have heard by as much as 0.4 seconds.
Look at some of those 11 second bone stock Z06s and I can almost guarantee that at least some of them are power shifting.
When power shifting is done right. The car sounds like an automatic.
Old Aug 27, 2005 | 12:16 PM
Pio's Avatar
Pio
Hi EB20003! Pleased to meet you! Its actually very easy to shift without using the clutch (and not grinding the gears) next time you go for a ride simply keep your hand on the gear ****, theres a point in the rpm range where the shifter will easliy slip out of its gear with just a bit of pressure. At this point, and without increasing the revs, with a bit of pressure it will "click" into the next gear. I have only tried it on upshifts (1 to 2, 2 to 3, etc), never downshifts.
I've never done it during a race, only cruising around. It impresses the passanger
While writing about Z06 Car And Driver (or one of those mags) said that John Heirency shifts w/o using the clutch to get those great times Chevy qoutes in their ads. I'm pretty sure they meant powershifts and not clutchless shifts. I doubt the Tremec would even shift that way at full throttle and I sures hell wouldn't try it.
Old Aug 27, 2005 | 12:22 PM
'06 Quicksilver Z06
While writing about Z06 Car And Driver (or one of those mags) said that John Heirency shifts w/o using the clutch to get those great times Chevy qoutes in their ads. I'm pretty sure they meant powershifts and not clutchless shifts. I doubt the Tremec would even shift that way.
Good to meet you too, sir
After I wrote that, I thought of my younger brother, who has never owned an automatic transmissioned car in over 20 years of driving, who told me this same thing about matching the RPMs and it being possible to shift without the clutch.
Like you, he once told me that he had tried it a handful of times over the years in city driving and on upshifts.
However as a matter of routiene he uses the clutch.
Old Aug 27, 2005 | 04:46 PM
jschindler's Avatar
jschindler
I used to be a powershifting fool (for many, many years). I found out the hard way on the 2001 C5 I had that they don't like it. The synchros were the week link.
I don't know if the C6 is any better, but I only powershift in extreme situations now - very seldom.
Old Aug 27, 2005 | 05:02 PM
ProfMoriarty's Avatar
ProfMoriarty
Yet another reason why I will never buy a used sports car!
To Power Shifting !
