Oil Temp 250
Old Aug 28, 2005 | 10:27 AM
Rogersvette's Avatar
Rogersvette
4th Gear
Default Oil Temp 250
I have an 86 vette and live in Yuma, AZ- I am thinking of taking a trip up the coast next weekend-
For some reason, (keep in mind it is 116+ outside temp here on any given day) the oil temp is running at 250. It doesn't get a chance to get out on the hwy often-
I have just replaced the radiator and am using Mobile 1 synthetic oil--
Any suggestions of what else to do?
I don't want to take a chance being stranded somewhere--
Old Aug 28, 2005 | 11:14 AM
iluvmyc6's Avatar
iluvmyc6
One suggestion... trade it in for a C6.
Old Aug 28, 2005 | 11:35 AM
AU N EGL's Avatar
AU N EGL
Take a high pressure air hose and blow the dirt, sand, grass and crap out of the radiator. You would be suprised and how much crud gets up there and what cleaning will do to lower temps.
Old Aug 29, 2005 | 10:49 AM
Rogersvette
4th Gear
Default Just replaced radiator
Thank you for that advice---We just replaced the radiator---any other ideas??? It is really bugging me!
Old Aug 29, 2005 | 01:54 PM
Hoonose's Avatar
Hoonose
Better to post in the C4 technical section.
This is C6!
Old Aug 30, 2005 | 11:35 AM
Michrider's Avatar
Michrider
Is the engine temp running normal? If so, I wouldn't worry about it. Mobil 1 can handle 250, if thats the highest it is going.
If the engine temp is running hot, look into a fan or thermostat problem.
Old Aug 30, 2005 | 08:45 PM
LS WON's Avatar
LS WON
Default You are in the wrong neighborhood. Try posting this in the C-4 section.
To Oil Temp 250
