I guess I'm the only one who likes the feel of the C6 spring...No spring or C5 spring just adds pedal pressure IMO.
The clutch is fine, the removel of the spring is a bad idea. plus the pedal hangs a little. Not to mention it feels funny. Not only, because GM says there's a reason it's there.
Well, I'm not far from your opinion on the spring. After 2 sprung years with my '08, I popped the spring out about a month ago to see what all the forum chatter was about. Yeah, the pedal effort is a bit higher now, but I don't notice any benefit. I never had any trouble finding the clutch engagement point with the spring in my C6, or with the C5 I drove for 5 years.
[QUOTE=Rock'n Blue 08;1572908437 Not only, because GM says there's a reason it's there.[/QUOTE]
GM also says the glue worked on holding the tops together, and that you should not be able to type and address in the nav screen while the car is moving.
ok took it out and you can feel its a little stiffer, but its also feel better. it does not have the POP to it at the top of the pedal, that makes people engadge the clutch jecky sometimes.
Here is another OLD post that came to life after more than 3 YEARS, what is up with this? There are other much more recent and relevant threads that get closed after a MUCH shorter time!!!!!
I don't know. I found my spring on my floor mat and the rest is history. I am thinking about haing the dealership put it back in. I hate Houston traffic
First it is an assist spring as it cams over on the bottom of the pedal stroke so less pedal pressure is needed.
The second thing is does is acts like a return spring at the top of the pedal stroke as well.
So if you don't want the assist part of the spring that is fine, but you still need the return part of the spring working instead. Why, the top of the clutch pedal has a switch that is used for items like the cruse control, and if there is no return spring in place, then you hit a small pump in the vet, and pedal is going to dance off the top switch to disengage the cruse control instead.
The answer to the problem has always been to just swap the C6 clutch assist spring with a C-5 clutch assist spring instead.
The smaller C-5 assist spring (on the right) give less pedal assist as it cams over when the pedal is being pushed down, but make sure that the pedal stays all they way up against the clutch top switch when your foot is off the pedal instead.
Dano523...while you are technically correct with your post ^^^^ I can tell you in practice, I've had no spring for 8 years and only one time did my cruise control stop working due to this (and I use cruise a lot).
I (and many others) removed the spring to avoid the pedal stuck on the floor at high rpm shifts (along with the Ranger fluid changing method). It is extremely effective at this. I've removed half a dozen springs at the track and cured every stuck clutch issue.
I have a c5 spring and tried it - it did NOT prevent the clutch sticking down at high rpm shifts, it continued to stick down with the c5 spring.
Drilling the 3 orifices restrictors out of the OEM fluid line will also solve the problem correctly for strip running instead.
So the first problem with the stock clutch is you have a lot of spinning mass at high RMP's slowing the clutch from re-engaging via the clutch fingers. Throw in the restrictions in the fluid line slowing the fluid returning to master cylinder as well, and now the spring fingers are fighting against that too. When the fluid gets contaminated with clutch dust, the fluid flows even slower back through the line to the master cylinder even more.
So pulling the assist spring may help a touch from the pedal sticking to the floor, but even with the spring removed, your still have the clutch slowly engaging/burning up as you come off the pedal with the restrictors in play.
Similar experience here. Haven't had the spring for over a year. Pedal comes high enough on it's own to hit the switch. I've never had an issue with cruise not working as expected.
Dano523 you make some terrific posts around here so I say this with all due respect. In this case I disagree with you based on real world experience.
Removing the pedal spring doesn't "help a touch", it absolutely fixes the problem when combined with the Ranger fluid method.
And it fixed the problem for the 6 guys I can think of at the track that I removed their spring, along with many others on this site.
To drop the drive train to drill out the clutch line is obviously a lot harder than taking the pedal spring out. I do know we used to do the "drill mod" to our F-body clutches which are obviously a lot easier to get to.
I daresay after 497 launches like this and 79,000 daily driving miles, I haven't "burned up" my clutch. It operates today just like it did 9 years ago and still gets 1.4 60 foots when I want to.
