F55 modifications
Old Oct 20, 2005 | 12:08 PM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Default Z51 bars change ride
Z51 sway bars installed on my F55 have tightened the handling and the ride quality. If you do much bad road driving(uneven pavement or tar strips), you will notice a harsher ride, even in touring mode. So there is a possible down side, depending on your ride quality tolerance, but the handling is tighter and it IS flat in turns!
Old Oct 20, 2005 | 07:42 PM
Black04Vert's Avatar
Black04Vert
Originally Posted by billsee
It'll take someone who was tech or engineer in F55 development to answer this precisely but I'll spit it out anyway and hope.:
1. Will increasing the swaybar diameter (say to Z51 or Z06) seriously reduce the F55 computers ability to maintain a stable platform?
2. How sensitive is F55 to changes in unsprung weight? If I changed to bigger disks and calipers (heavier?), forged wheels (lighter) or aftermarket Z06 wheels (heavier) does this seriously alter the damping?
3. I can't imagine "tuning" F55 like some people can do with engine management, but are unsprung weight and/or swaybar stiffness externally-accessible tuneable constants?
IMO, changes to unsprung weight, vehicle loading etc will not affect the F55 logic. I do not believe that the shock will under-correct damping due to the added weight or by changing the sway bars for that matter.
My reasoning is that control systems can be roughly divided into two groups, closed loop and open loop systems. Open loop systems generate a response based entirely off external inputs. Closed loop systems generate a response from both external inputs and feedback from the control system itself. It would be ridiculous to build a (near) active suspension based off open loop logic. Variability in parts, manufacturing, age of components, vehicle loading etc would cause havoc on this type of system especially considering the number of inputs. More likely, the F55 logic adjusts every subsequent damping response based off the current position of the shocks and their rate of change in addition to the host of other inputs. But then again ... I ain't no GM engie.
Old Oct 20, 2005 | 07:49 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Originally Posted by scrannel
Personally I think the Z51 is an over-with technology with a very narrow purpose when compared with the astounding F55.
Earthshaking. What is your opinion on other time tested and true technologies, such as running water and internal combustion engines?
Old Oct 20, 2005 | 08:31 PM
scrannel's Avatar
scrannel
Well, water is fine, but do we still have to deliver it in lead-lined copper pipes? And the internal combusiton engine...? We all know it's just a matter of time, right? The Z51 is a fantastic package, considering everything else you get with it. But I was refering specifically to the suspension. If I could have gotten a package that included all that you get with the Z51 but with the mag shocks, I would have bought it. But then it would have been twice the price of either option alone. Still, I would have done it in a second.
Old Oct 20, 2005 | 10:00 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
My '03 coupe has F55 and a fair bit of suspension related mods: Hotchkis swaybars, tunnel reinforcement plate, eradispeed 2 piece rotors with +1 in the rear, oem z06 wheels that went through an aftermarket chroming, and BFG KD tires (non-runflat). It definitely hugs the road better and has a stiffer ride. I think it understeers a bit more than the stock setup. I haven't had anything in the f55 computers tuned, afaik. My custom dynotune was for the supercharger/cam and everything else.
You can still do a lot of suspension mods with f55 to change its handling, and it won't thoroughly confuse the programming for f55.
Old Oct 20, 2005 | 10:44 PM
billsee's Avatar
billsee
F55 IS a feedback system. A nonlinear feedback system, which is not traditional and much more difficult to analyze and design. When you change anything in a feedback system you could degrade its response. Actually, if well designed, you WILL degreade the response from the design goal. That doesn't stop me: MY desired response is probably a little more "sporty" than the designer was told to provide
If F55 seperates roll inputs from other inputs I'm convinced stiffer swaybars won't hurt its response to other inputs terribly. Comments from those who did it kinda confirm that. A modest increase in harshness for better turnin sounds a reasonable tradeoff to me. I'll go with Z51 bars, leave Z06 bars to someone with more guts than me. Im off and running. Thanks for all the input on that guys.
Still hanging is the question of "how much additional unsprung weight (different tires/rims, different brakes) can F55 handle without acting upset?". I'll try asking GM if there's a way to ask.
Old Oct 20, 2005 | 10:59 PM
billsee's Avatar
billsee
Default Thanks
Thanks for all the great input, GTC the latest feedback but lots of good information from others. I'm really excited to get on with this.
Scrannel, I'm with you. Too bad GM can't handle a little more individuality in the Vette.
I would happily pay $1000 more for a slicker manual transmission. But the base car price would have to increase to pay for the additional choices: more engineering, toughter logistics in production, very expensive safety and pollution tests for all the combinations.
Some would have to take a Mustang and we wouldn't want that, would we?
Old Oct 21, 2005 | 06:16 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
just curious, would replacing the stock sway bars with either the z51 or z06 ones permit the dealer to deny warantee work if a shock or something else went wrong with the f55 system ?
Old Oct 21, 2005 | 07:13 AM
V Vette's Avatar
V Vette
They probably wont even know the difference!
Old Oct 21, 2005 | 07:48 AM
Miaugi's Avatar
Miaugi
Old Oct 21, 2005 | 09:51 AM
billsee's Avatar
billsee
Default How To Change
Outright failure of F55 couldn't be attributed to changing the bars. More subtle changes might raise the issue that your mods are involved. Since bone-stock sway bars have essentially zero value, it would be prudent to keep the olds one around in case you ever wanted to change back, either to prove something to a dealer, or to prove it to yourself.
Four bolts hold the rear swaybar. On a flat, level surface, is the bar under tension? How easy is it to roll the car up on ramps and change? Or jackstands? I've never done it.
Old Oct 21, 2005 | 10:21 AM
scrannel's Avatar
scrannel
billsee, here's a couple of install links in case you have not seen them.
http://forums.corvetteforum.com/show....php?t=1045925
http://forums.corvetteforum.com/showthread.php?t=990020
Old Oct 21, 2005 | 10:14 PM
  #33
Wass's Avatar
Wass
St. Jude Donor '09-'11
I asked that question of the service manager at the dealership where I bought my C6. He said they would not harm the warranty.
Old Oct 21, 2005 | 11:14 PM
  #34
purple heart's Avatar
purple heart
Just out of couriosity, what could go wrong with changing theZ51 sway bars with a stock suspension? Are there computers afftecting the ride similiar to the F55 computer or do computers not enter into the equation?
Old Oct 22, 2005 | 12:57 AM
  #35
Black04Vert
Nothing could go wrong by putting Z51 sways on a base suspension. There is nothing computerized with base or Z51 shocks.
Old Oct 23, 2005 | 11:44 AM
  #36
scrannel's Avatar
scrannel
There has to be plenty of latuitude in the system -- people put on different tires and wheels on a regular basis.
Old Oct 23, 2005 | 02:52 PM
  #37
LS1LT1's Avatar
LS1LT1
Originally Posted by Daylon
Put Z51 bars on my F55, best money I ever spent! Much better handling, no down side that I know of....
Well there is one small downside, those thicker sway bars DO weigh a tiny bit more.
To F55 modifications
Old Oct 24, 2005 | 12:46 AM
  #38
LS WON's Avatar
LS WON
Plus if you don't drive like that you won't notice the difference anyway would rather have the more comfortable ride which is more useful especially on these torn up roads.
Old Oct 28, 2005 | 02:03 PM
  #39
jeffgdula's Avatar
jeffgdula
Although, I found this interesting: "On Germany's bumpy, challenging Nuerburgring circuit--an increasingly popular suspension-development venue--they report that the F55-equipped Corvette is actually quicker in the Tour mode."
Link for that is: http://motortrend.com/roadtests/coup...0208_corvette/
Nevertheless, I am going with the Z-bars.
That article says its quicker in Tour than Sport mode, not quicker than the other suspensions which is what you or someone else claimed in another thread. Not too mention it was about C5's and the C6 Z51 is much more comprehensive than the its C5 ancestor.
And as far as your comment that "the Z51 is an over-with technology with a very narrow purpose when compared with the astounding F55" its funny that an "over-with technology is still in 99.9% of all cars made today.
And of course it has a narrow purpose, so does the Corvette: to be a sports car. This would be in contrast to MSRC cars. As the article points out, the only other cars with MSRC are both Cadillacs and I think anybody who buys a Vette with MSRC should have just bought a Cadillac anyways since that is clearly the ride they were looking for.
Old Oct 28, 2005 | 03:24 PM
  #40
jschindler's Avatar
jschindler
Originally Posted by jeffgdula
.....points out, the only other cars with MSRC are both Cadillacs and I think anybody who buys a Vette with MSRC should have just bought a Cadillac anyways since that is clearly the ride they were looking for.
Jeff, have you ever ridden in a F55 car? Come to Houston, I have one. Bring a Z51 car, and bring cash. We'll go to an autocross and see how much difference it makes
I've had both Z51 and F55 C6's. You people who think the Z51 is the end all, and that all Corvettes should have it sure are narrow minded. I don't criticize anyone for their choices. But I see an awful lot of Z51 fans acting like if you don't by Z51 you are some kind of second class citizen. The really annoying part of it is that most of the Z51 zealots have never spent any time driving the other variations.
If you have Z51, and it's the only way you would by a Corvette, that's fine. But please quit talking down to those who don't have it as if they are idiots.
