Help - Clutch Problems
Old Dec 16, 2005 | 01:20 PM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
Default Help - Clutch Problems
Just got a 2005 C6 MN6 on a lease takeover. Had the car shipped half way across the country. Car arrived last night with a dead battery of course. However, I cannot shift the car into any gear with the car running, I have to shut down the car, put it in first gear and then start it up and drive. If I have to back up, then have to shut the car off, put in reverse and then start the car again.
Clutch pedal is half way to the floor before you touch it (relative to the brake pedal anyway).
It also seems like the clutch is slipping when I drive the car.
Any thoughts????
Thanks.
Old Dec 16, 2005 | 02:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Wow,,,that sucks, check the clutch fluid. If it is low, the system most likely has air in it. The slipping part bugs me, that is BAD! Doubt if the OEM warranty will cover that!!
