is there other way 2 lower C6
Old Jan 3, 2006 | 02:40 PM
csex's Avatar
csex
Default is there other way 2 lower C6
I have replaced the rear bolts to lower the rear end on my C6 but couldent stand the harsh ride so i put the original bolts back...
guess what the car is even higher than what it was before....
Any suggestion on alternative method on how to lower a C6
mine has F45 syspention
thx
Old Jan 3, 2006 | 03:11 PM
LS1LT1's Avatar
LS1LT1
F55 you mean, it hasn't been F45 since the C4s I think.
Old Jan 3, 2006 | 03:24 PM
davidfarmer's Avatar
davidfarmer
you could buy drop spindles that a few WC teams use. They are about $1000 EACH.
Your car should settle back down to the original height over a little time. The way the suspension works, the bolts are in shear as well as compression, and everything takes a bit longer to settle due to the combined loading.
Old Jan 4, 2006 | 09:20 PM
glass slipper's Avatar
glass slipper
The rear bolts are in tension only...not compression and certainly not shear!
Old Jan 5, 2006 | 08:32 AM
davidfarmer
In the C5 they were in Tension, but on the C6 they are in compression, just like the front. The sheer comes from the fact that the control-arm length and the spring-arm length aren't the same, therefor the contact point moves back and forth slightly as the suspension travels up and down.
If you take the lower control arms off, you will see that the contact patch is not round, but it is a stretched out Oval, due to this sideways movement.
The C6 adjusment is more elegant, but much harder to lower very much.
Old Jan 5, 2006 | 03:06 PM
aaaaa's Avatar
aaaaa
Old Jan 5, 2006 | 10:58 PM
glass slipper
Sorry, got confused with the C5. :o
Old Jan 9, 2006 | 07:05 AM
csex's Avatar
csex
Default sorry 4 the mix up
Its F55 as my car is 2005 C6,
Its been like a nightmare since I put the original bolts back on the rear
The car is behaving nervously over small pumbs or holes.I can feel the rear end is not stable and ready to lose and more weight is on the front end.
Its been over a month ats its not back to original height..I wonder if the mechanic fixed then proparly..
Its too bad there is no cheap mod to lower it and keep the rubber insulation.
Old Jan 11, 2006 | 08:01 AM
csex's Avatar
csex
Default is cadillac XLR rear syspention any better
I am just wondering if the cadillac XLR rear set up can be used to lower and soften my C5 rear syspention....any thoughts on this ?????
Old Jan 11, 2006 | 08:19 AM
davidfarmer
there simply isn't enough room between the spring/arm to lower the car enough without removing the joince rubber.
There is a chance you could remove the spring, cut the rubber off of the top of the spring and re-install it. This would move the spring higher into the car. This is the way we use to lower C4 Corvettes.
To is there other way 2 lower C6
