I use DOT 5 whenever I change a system -- always for my motorcycles.
DOT 5 or DOT5.1 ?? Motorcycles are different.
DOT 5 is a SILICONE BASE product. It does not absorbe water, which sound like a good thing. However, Silicone base fluids do not lubracate eh PBR brake caliper ABS system. If you brake hard and over heat a silicone fluid it will foam, not boil. Plus WHEN not IF, but when water gets into the brake system it will bead up in the silicone fluid and again cause the fluid to foam.
when DOT 5 foams it will not work, i.e. your brakes are screwed and wont stop the car.
The Motcycle brake system may require or work with the DOT 5, but ABS car and truck brakes dont.
May want to consider changing out the DOT 5 fo a good DOT 4.
DOT is a SILICONE BASE product. It does not absorbe water, which sound like a good thing. However, Silicone base fluids do not lubracate eh PBR brake caliper ABS system. If you brake hard and over heat a silicone fluid it will foam, not boil. Plus WHEN not IF, but when water gets into the brake system it will bead up in the silicone fluid and again cause the fluid to foam.
Thanks for the info -- have never had a problem with my bikes on DOT 5. Have not touched my Vette. What is 5.1?
DOT 5.1 is a synthetic glycol. This means it is compabible with the brake fluid that is already in the system, and has the same dry and wet specifications as the DOT 5 silicone fluid. DOT 5.1 is basically just a really good batch of DOT 4.
There are 2 problems with DOT 5 in automobiles. 1) it is a bitch to get the fluid in without tons of microscopic air bubbles which will destroy the firm pedal feel. 2) it is incompatible with the ABS function.
If you aren't doing track events (or even if you are, really), I'd got with something like Valvoline Synpower. It is readily available, and with 6% of the boiling points of SuperBlue.
Racing fluids have awesome dry boiling points, but they absorb moisture really quickly, and lose several hundred degrees of boild points when "wet". Unless you plan on bleeding your brakes every weekend (like racers do), then you won't really gain anything with a racing fluid.
