1. I have the base stereo because I knew I was ripping it all out. I am only using the harness for powering the unit, I amplified all the other speakers and subs so there was no need to connect the stock amp. The harness however says it will be no problem if you want to.
2. You need a dash kit, Metra sells a double din dash kid for the Vette.
3. My nav antenna is mounted underneath the dash, on top of the AC vents. Works perfect, it's right next to my XM antenna, there are NO exposed antennas on my car.
4. You will need an aux adapter. If you are using an ipod they sell an ipod interface specifically for the pioneer. If you are using another outside source you will need the CD - RB10 or CD-RB20 aux input converter.
Thanks again. One more question. Where do you find the dash kit? None of the on-line sites I have checked have the right one. If you don't want to say here, please PM.
