Replacement Head Unit?
Old Mar 11, 2006 | 04:09 PM
S2K's Avatar
S2K
Default Replacement Head Unit?
Does anyone make a replacement head unit for the C6?
Old Mar 11, 2006 | 09:40 PM
The Garage Master's Avatar
The Garage Master
Nav non Nav? My Kenwood fits in the Nav spot.
Old Mar 11, 2006 | 10:11 PM
S2K's Avatar
S2K
Non-nav. I have the base radio. Anything that can be used without having to rewire?
Old Mar 11, 2006 | 10:17 PM
The Garage Master
Everything has to be rewired if you replace it.
Old Mar 11, 2006 | 11:18 PM
S2K's Avatar
S2K
Crap. Why does this have to be so damn difficult. Why couldn't they have just put an AUX port on this thing?
Old Mar 12, 2006 | 01:44 AM
C6dude's Avatar
C6dude
I ordered mine without the nav unit so I can purchase a better aftermarket unit. Look at the Eclipse avn5495 . It is awesome and it works with all factory chimes and acc.heres a link
http://www.crutchfield.com/S-PjOuxRr...p?i=099AVN5495
Old Mar 12, 2006 | 02:43 AM
S2K's Avatar
S2K
Cool if expensive. Does it work with the factory harness or do you have to rewire the car?
Old Mar 12, 2006 | 08:54 AM
SickRick's Avatar
SickRick
Alot of folks (myself included) have done the Pioneer AVIC-D1 Nav unit also. There are adapters that allow you to use the factory Blose Amp/Spkrs (YECH!), or use the adapter to maintain chimes & RAP - change out the speakers, add a REAL amplifier. In that case, you WILL have to run new speaker wires, and lines from the head unit to the amp - but the difference in sound quality (if you care about sound) is amazing.
Rick
Old Mar 12, 2006 | 08:56 AM
serendipity's Avatar
serendipity
Since you posted in the C6 Tech section, and not the Audio section, I assume you're really talking about a supercharger head unit, right? Swapping a D1 for a P1?
Old Mar 12, 2006 | 10:48 AM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
Try this if you are just looking for an AUX port.
http://cgi.ebay.com/PAC-AAI-GM24-Aux...QQcmdZViewItem
Old Mar 12, 2006 | 10:57 AM
S2K's Avatar
S2K
Thanks for giving this link. Unfortunately I don't have a lot of trust for these things and zero if there is no return policy. For example, I purchased a SoundGate AUXGMV3 from Logjam. I wasted an entire Saturday, but couldn't get it to work. They sent me a replacement assuming the first was bad. I just spent this Saturday trying to get it to work. No dice. So, even though they say it will work doesn't mean it will. It's also obvious that they didn't test it on the different versions of the C6 radio. For example I think the Aux above will work on the 1SB version of the C6's radio, but I doesn't in the 1SA version which I have.
Old Mar 12, 2006 | 10:59 AM
S2K's Avatar
S2K
Rick
Where are these adapaters and can they be used with other HU's? It's not that I don't care about sound, it's just that I do my serious listening on a top flight home unit.
Old Mar 12, 2006 | 10:22 PM
S2K's Avatar
S2K
I understand that the PAC C2R-GM24 may work with the 1SA model (which I believe is non-Bose). Has anyone used this?
Thanks.
Old Mar 12, 2006 | 10:27 PM
S2K's Avatar
S2K
Also, for those that put something new in, did you need a dash kit or did it fit perfectly?
Old Mar 13, 2006 | 03:19 PM
isnider's Avatar
isnider
Does not work....been there done that. (still waiting for someone to come out with something)
Ian
Old Mar 13, 2006 | 04:54 PM
Waveblaster785's Avatar
Waveblaster785
I rewired my non-nav radio. You plug in the harness and hook up the wires. It was terrible though, took me a whole 10 minutes TOPS.
The people who complain the most about these cars and how hard they are to work on are the people who have never tried but heard from others like themselves that it was hard.
I bought a PAC harness off Ebay. Plugged it in, and hooked it to my Avic D1, I could do the job over again in a matter of minutes. Of course I also ran all new amps, speakers and subs, but I hear that's damn near impossible too.
Old Mar 13, 2006 | 04:55 PM
Waveblaster785
Thanks.
It's currently running my AVIC-D1.
To Replacement Head Unit?
Waveblaster785
Ian
Why doesn't it work?? Please enlighten me....I'll BRB I gotta go tell my stereo to stop working because you said so.
If you take the time to look in the FAQ, there is an excellent write up by another member who installed his Eclipse unit by using the PAC harness as well.
All of my chimes still work, and my headunit stays on until I open the door. So I'm not sure WHY it doesn't work. I didn't use the factory speakers, but that's just a couple more wires to hook up. I think you were possibly misinformed or just did something wrong.
Old Mar 14, 2006 | 12:13 AM
S2K's Avatar
S2K
Thanks a lot for this information. Very encouraging! A few questions:
1. Can you confirm that you have a 1SA model?
2. Did you need to use a dash kit or some other trim or did the radio fit perfectly?
3. Where did you mount the nav antenna?
4. Where is the AUX port located on this unit. I could not see it in pictures.
Thanks again!
Old Mar 14, 2006 | 09:16 AM
Waveblaster785
Thanks again!
1. I have the base stereo because I knew I was ripping it all out. I am only using the harness for powering the unit, I amplified all the other speakers and subs so there was no need to connect the stock amp. The harness however says it will be no problem if you want to.
2. You need a dash kit, Metra sells a double din dash kid for the Vette.
3. My nav antenna is mounted underneath the dash, on top of the AC vents. Works perfect, it's right next to my XM antenna, there are NO exposed antennas on my car.
4. You will need an aux adapter. If you are using an ipod they sell an ipod interface specifically for the pioneer. If you are using another outside source you will need the CD - RB10 or CD-RB20 aux input converter.
