Fluid question..... Tranny/Diff
Old Mar 22, 2006 | 12:00 AM
lytmup's Avatar
lytmup
Default Fluid question..... Tranny/Diff
Ok, its coming up time to do my first oil change on my car. At the same time, I was thinking about changing the differential fluid and transmission fluid after seeing other posts on here about Royal Purple maybe making the tranny shift a little better.
Anyone with an opinion on this?
oh. Its a Z51 6-speed.
Old Mar 22, 2006 | 12:16 AM
NORTY's Avatar
NORTY
Does it call for ATF in the stick? If so,then use just about any ATF there is as they all meet the "H" designation. For the diff,I'd say Shell Spirax LS 80W-90. For the most horsepower, use Quakerstate "Q" synthetic oil in your engine. (I can't believe I'm saying this...)
Old Mar 22, 2006 | 11:29 AM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
Yes, the stick calls for ATF. RP's syncromax is intended for manuals that use ATF.
I gave the RP treatment to mine. The shifitng is a bit smoother and I like it. It's not a night and day difference, but definately noticeable. The only noticeable difference in doing the diff too, is that some say it makes it quieter. I believe it since changing the diff oil is what the dealer will try first if yours makes noise. Mine never made any noise, so I can't tell the difference. But I feel a lot better driving the car hard knowing that the original oil is no longer in there. It was quite dirty when I drained it.
Old Mar 22, 2006 | 12:14 PM
nowheelie's Avatar
nowheelie
For my tranny I put the RoyalPurple syncromax, which made a big difference with my b&m shifter. I installed the shifter prior to the tranny fluid change, I definitely needed the syncromax.
A while ago I swapped the diff. fluid with RP maxgear, big difference for me there too. Immediately the tranny was quite during cold turns, and the car no longer does cold 'lurches'. Still loving it hundreds of miles later.
Old Mar 22, 2006 | 01:15 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I also changed the trans and rear fluids with RP.
Old Mar 22, 2006 | 02:45 PM
AU N EGL's Avatar
AU N EGL
Trans M1 synthtic ATF
Diff M1 synthtic gear oil 75-w90
Old Mar 22, 2006 | 06:29 PM
AintQik's Avatar
AintQik
I used Redline in the tranny. Worked well and got it next day from one of the big mail-order parts places I can't mention on this site.
To Fluid question..... Tranny/Diff
