Headers alone gains???
Old Mar 22, 2006 | 08:21 PM
Hippiehead025's Avatar
Hippiehead025
Default Headers alone gains???
I wannak now what yall got as far as Hp/TRQ increase, with what brand headers. No tune, no anythign else, if possible, just headers. before and after..... Lookin to see what headers get the most gain total. I looked and looked and found little to no info on ppl's gains with JUST headers, every1 else had other mods.... TY - Roger
Old Mar 24, 2006 | 02:50 AM
C6vertboy's Avatar
C6vertboy
You should always tune when you change the air flow in your system to get the best results. I'll try to get one with & without the tune + headers then tune with headers if they don't charge me more. Just for you!
Old Mar 24, 2006 | 06:57 AM
AFVETTE's Avatar
AFVETTE
I gained 25 RWHP/Torque on my 99 LS1 w/o a tune. With a tune I may have gained another 8 to 10. I was runing real rich and installing the LT leaned the car just enough that I didn't really need or want a tune.
Loads of variables, but ball park HP gains of 25 are common.
Tom
Old Mar 24, 2006 | 07:03 AM
vettee's Avatar
vettee
Which brand has max increase?
Old Mar 24, 2006 | 09:35 AM
NASTYZO6's Avatar
NASTYZO6
LOOK AT THE ZO6 TREAD 21ST CENTURY GOT BIG POWER WITH THE AMERICAN RACING VETTE DOCTORS HEADERS
Old Mar 24, 2006 | 11:21 AM
Hippiehead025
cool thanks yall!
Old Mar 24, 2006 | 11:27 AM
Zred06's Avatar
Zred06
I just talked to a tuner and said I was wasting my money by tuning with only the addition of headers, intake and exhaust. He could have made an easy $200 off of me, but instead said it wasn't worth it, he claimed that the factory computer will adjust to air/exhaust flow changes with time (takes some miles). He only said it would be necessary to tune if I installed cam or heads or supercharger, etc.
Old Mar 24, 2006 | 12:41 PM
SpinMonster's Avatar
SpinMonster
Gains on a 427 aren't indicative of what you would gain on the LS2 with headers.
Old Mar 24, 2006 | 12:44 PM
SpinMonster
Not true. While the PCM can compensate for long term fuel trends within a range, the change that headers cause is a lean condition in closed loop which causes the PCM to compensate at wide open throttle by dumping fuel that causes the car to be super rich there. This is bad. If your tuner doesnt know this then I wouldnt let him tune my car even if I could get it for 200 bucks.
Old Mar 24, 2006 | 12:49 PM
rfopt's Avatar
rfopt
I guess it's interpretation. Your car may still drive ok. But a good tune will allow your modifications to work to their full potential. I figure what's another 200-500 dollars when I paid all that money on headers, intake and exhaust.
Old Mar 24, 2006 | 01:10 PM
Zred06's Avatar
Zred06
I sure would like to see evidence of this, then I could go to the tuner and show them. I hear a lot of opinions on this forum and I would like to see the facts.
Old Mar 24, 2006 | 01:41 PM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
You mean that we should't believe everything written here? My my. LOL Bill
Old Mar 24, 2006 | 08:51 PM
Zred06's Avatar
Zred06
A little further follow-up, I talked to a second tuner today who told me it was $500 for custom tuning but he talked me out of doing it sice he said it won't give more than 5-10 hp increase. He said if you just add headers alone, there would be benefit in tuning but when you add a Cold Air intake then the balance between exhaust and intake is restored to within the range of compensation that the factory PCM can adjust to (+/- 15% FAR variance). So I am fairly well convinced that I really willl not get much bang for my buck from tuning....unless someone can prove it to me with facts.
Old Mar 24, 2006 | 09:30 PM
Kappa's Avatar
Kappa
I think tuning has a big effect on these cars. My friend installed a Vararam on his '03 Z06 and after driving it around for a few weeks had it on the dyno. The car made 355rwhp and the guys at MTI Racing found that the computer could not compensate for the extra air as the injectors were at a 100% duty cycle! 2 days later under similar conditions and tuning the car made 377rwhp.
Old Mar 24, 2006 | 09:43 PM
dennis50nj's Avatar
dennis50nj
that wasn't an ls2
Old Mar 24, 2006 | 09:46 PM
Zred06's Avatar
Zred06
You missed my point that if you install headers AND intake, then you will not benefit much from a tune, if you install an intake without headers, then yes, you will need a tune to compensate for the abundance of intake air. If you add headers without an intake, then you will need a tune because the exhaust is now sucking but the air supply is limited. Add them both and intake and exhaust will work in harmony within the limitations of the stock PCM.
Old Mar 24, 2006 | 09:51 PM
shurite44's Avatar
shurite44
I would not spend that sort of money on these mods and not get the car dyno tuned. I agree with the spin monster on this one.
You say you want some proof, well I have none. But I have been reading posts on C5's and C6's for a couple years now and I can tell you a tune helps.
On my two C5's I just used a handheld tuner and it made a significant difference in performance. Around 2 tenths in the qtr mile, so I know a dyno tune would be at least this if not another tenth.
I think you will see close to a 15-20 HP difference between a tune and no tune with a CAI and Long tube header install.
Just my opinion.
Old Mar 25, 2006 | 06:26 AM
cbrf4i1's Avatar
cbrf4i1
a tune will help to get rid of timing retard on hard shifts, lean out the a/f ratio a little (within reason) and add a few degreees of timing here and there, these three changes will add 8-15ish hp/tq or more (depending on how aggressive the tune is). as far as the headers and air intake are concern, the pcm while in close loop will be able to see the increase in air flow (caused by the better intake and exhaust) from mass air meter data and add additional fuel to stay within the predetermine wot a/f ratio. (there will be some fine long and short term fuel adjustments) i am assuming the injectors are still under 100% duty cycle, i am sure it is if that is all your mods. so you will see gain from your mods without a tune....just no additional hp/tq from lean out wot a/f ratio / getting rid of timing retard on hard shifts or additional timing.
To Headers alone gains???
