Which Oil Filter?
Old Apr 1, 2006 | 05:14 AM
LS WON's Avatar
LS WON
Originally Posted by AAONMS
Isn't this now outdated as this was done sometime ago in 2003?
Old Apr 1, 2006 | 10:40 AM
xs650's Avatar
xs650
Originally Posted by C6dude
I am going to use this Ultra Filter on my SC402 . heres a pic of mine taken apart and a link to their site. What do you guys think about their claims. It definitely looks like it will flow and filter better than a paper filter, I don't know about their HP claims though.
http://store.yahoo.com/hopup1/troilfiforgm.html
The power claims are bogus as is their claim that it filters better than a "paper" filter.
Another example of BS is:
Paper filters have a “Bypass” that opens at 12 lbs of pressure. Most motors idle at 11lbs of pressure. At 12 lbs, the bypass opens and filtering stops. All of the dirt and metals are then sent back into your motor. Paper filters only filter 10-20% of their actual life.
They either don't have a clue how a bypass in an oil filter works or are less than honest.
Old Apr 1, 2006 | 11:23 AM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Originally Posted by xs650
The power claims are bogus as is their claim that it filters better than a "paper" filter. Another example of BS is:
I agree with xs650. I would stay away from those lieing bastards. Any idiot knows that it is DIFFERENTIAL pressure that causes a filter to go into bypass mode. For them to confuse differential pressure with system operating pressure proves they are either ignorant or dishonest.
I use the A/C Delco UPF 44 which was shown to be a very good filter on one of the websites. I beleive it has sysnthetic media as well (the standard PF44 does not).
Old Apr 1, 2006 | 11:39 AM
Bandit1's Avatar
Bandit1
Originally Posted by LS WON
AC-Delco UPF-44 Premium
Old Apr 1, 2006 | 11:48 AM
BIG Dave's Avatar
BIG Dave
A/C Delco UPF 44
Old Apr 1, 2006 | 12:02 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
The source site, which is much more updated than the one you linked above is www.oilfilterstudy.com
But, even this one is a few years behind the current filters on the market. Still has some pretty interesting info though.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Apr 1, 2006 | 04:33 PM
C6dude's Avatar
C6dude
I don't believe their claims but I believe it is MUCH better than any paper filter available. I filters much finer particles and much more flow. I did some research on stainless steel oil filters and they are being used a lot on Bikes and race cars. Here is some more links
http://www.gopurepower.com/
http://www.gopurepower.com/store/ite...em&itemKey=664
http://www.motoworldracing.com/ready...oilfilter.html
http://p2library.nfesc.navy.mil/P2_O...ok/6_II_2.html
Old Apr 1, 2006 | 04:53 PM
xs650's Avatar
xs650
Dude, the URLs you list are people trying to make money off those filters with disinformation, except for the Navy site which just parrots some of the vendors BS
For the amusment of those who understand filters, I offer this quote from one of the URLs
5 Micron Material
Oil is 12 Microns; it can’t go through a 5 micron material. *Oil flows BY, NOT THROUGH.
I believe that's from the same people that claim regular filters bypass at 12 psi system pressure.
Old Apr 1, 2006 | 05:03 PM
C6dude's Avatar
C6dude
xs 650 Do you believe this is bull**** from the Navy site ? I quote a paragraph.
"Use of reusable filters reduces the quantity and cost of purchasing oil filters. Labor costs are equivalent or slightly higher for the reusable filter, but are off set by the elimination of the back end handling of disposable filters. In comparison to paper filters, reusable filters can remove up to 40% more iron, copper, lead, tin, and aluminum than traditional paper element filters, reduce silicon (sand and dirt) by up to 50% more than paper element filters, reduce the depletion rate of the oil additive package (TBN) by as much as 20% over paper element filters, and, when coupled with an engine oil analysis program, will extend engine oil life by as much as 67%, thus reducing the need and expense of oil changes."
Old Apr 1, 2006 | 05:21 PM
C6dude's Avatar
C6dude
xs650 Where did you find the "5 micron material" quote ? I could not find it anywhere on the URL's.
Old Apr 1, 2006 | 05:59 PM
xs650's Avatar
xs650
Absolutely. That's not the entire US Navy speaking, it's part of a publication put out with polution reduction ideas.
There is no testing to back it up and the Navy is not officially recommending adaption of those filters. It parrots vendors propaganda.
Old Apr 1, 2006 | 06:03 PM
xs650's Avatar
xs650
Reread the page at the 2nd URL you listed.
Old Apr 1, 2006 | 06:38 PM
  #33
LS WON's Avatar
LS WON
I wouldn't know because when I click on this site it says it is forbidden to enter..Also note I have also heard just go ahead and use the cheapest oil you can find just make sure you change the oil and filter more frequently. I believe they were stressing that its more important to change oil and filter sooner than later like some of these high priced synthetic oils used to claim the 15,000 mile change or 25,000 mile change.
Old Apr 1, 2006 | 06:50 PM
  #34
C6dude's Avatar
C6dude
you forgot this little part
"Filtration Rate (not screening material micron size) SAE J1858"
What that means is that it filters between 5 and 25 microns being at 25 with no restriction if you look at their chart posted. Regular filters filter between 20 and 80 microns so some stuff gets by it.
Also I don't know see any paper oil filter manufacturer not saying theirs is the not best filter. K&N ,Mobil 1, Fram etc.
I don't know what your qualifications are to dismiss all this as B.S. Do you think the Navy ,Aerospace, racing and the rest of these sites are somehow connected with their test results and are trying to sell you something ? Until I see a independent test done using stainless filtration as well as conventional paper/synthetic to show me otherwise,I will make my own judgement and stick with the stainless filtration on my 25K 1050hp motor. Thanks for your input
Old Apr 1, 2006 | 07:04 PM
  #35
xs650's Avatar
xs650
My qualifications are enough reading comprehension to figure out that the Navy site is only a polution reduction wet dream publication with no official standing. Also enough of a basic understanding of how lube systems work to know that there are outlandish claims being made that are either the result of abject ignorance or dishonesty.
It makes no diference to me what filter you use, or whether you even use filter. The purpose of my responses was to let others know that something smelled rotten in those claims.
Old Apr 1, 2006 | 07:09 PM
  #36
catbert's Avatar
catbert
Originally Posted by easyrider13
I'm using the AC Delco Ultra Guard UPF44.
It filters down to 8-10 microns (I think Mobil One filters to 10-12 microns).
Either is fine, and substanially better than the stock filter which filters to perhaps 25 microns.
I bought a case (6) from Bean's.
me too
Old Apr 1, 2006 | 07:29 PM
  #37
Patman's Avatar
Patman
Originally Posted by cleo
How do you know this?
Because I have seen a number of independant tests which show the Mobil 1 filter to be very restrictive. It's a great filter for a daily driver that doesn't see a lot of wide open throttle, but it's not a great filter for a performance car.
Also, don't be fooled into thinking these super fine filters are the way to go. You simply do not need a 5 micron oil filter in order to get low engine wear. I've got proof on that, since I use nothing but the K&N oil filter on mine, which is about a 20 micron filter, but yet I see extremely low engine wear in my oil analysis results. Lower than any other results I've seen posted for a Corvette actually. So obviously the filter does not need to take out super small particles. If you're running a good oil to begin with, there won't be a ton of metal particles in there anyhow! (I run German Castrol 0w30)
To Which Oil Filter?
Old Apr 1, 2006 | 07:32 PM
  #38
LS WON's Avatar
LS WON
Old Apr 1, 2006 | 07:50 PM
  #39
C6dude's Avatar
C6dude
I am not basing nothing on that site only even though I don't feel the same way you do about it. Do a search on stainless steel oil filtration. There is a lot more "propaganda " to read about. I did not spit out $150+ dollars on reading the navy site or my URL's posted alone if that's what you think. I just did a quick search for links to have people see some prices and "propaganda" to make their own descision if they chose to go that route.
You are just stating your opinion on you oil filter preference as I am . If you know that stainless doesn't filter as well or better ,I haven't seen you post any "propaganda" from other sites but your own. Are we just suppose to believe you because you cut down everybody that sells, produces or uses stainless filters with no proof ? or because of your of your "reading comprehension" ?
I'm done on this topic ,you can have last word
Old Apr 1, 2006 | 10:11 PM
  #40
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
I do believe these may be the same folks who came to BITOG and claimed that NO oil passes through a paper filter since oil was "bigger" than the 12-15 microns on the paper filters. Oil does go through the paper if you were wondering. They only claim a 35 micron absolute filtration rate whereas paper does tend to go under 20 so better filtration with paper/synthetic filter?
And there is no way ANY filter is going to give you a HP increase. Lastly, if we assume a good oil filter is 9 dollars, you can change your oil 11 times for the same price as one of these filters. For me, that would mean oil changes for 66,000 miles before I even break even. The one thing the BITOG folks agreed on is that the build quality seemed to be excellent.
A few people have tried it and it didn't seem to hurt anything but no one has run one for very long so the jury is still out.
For me, I will stick with either the UPF44 or the Amsoil filter.
YMMV and good luck. Are you going to do UOA's? Keep us informed.
